Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Describe your Intermatic &
Describe your Intermatic & Indoor/Outdoor Rain Tight Timer Problem
Timer is not shutting pump off
    President:
  • 1,723 Answers
Is the time clock rotating through the off tripper? If so, and the pump stays on, it's not wired right. Check the wiring at the clock for the pump.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
Tripper parts for Model HB35R
1) Copy following links to identify product and trippers, available at Intermatic store:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#P1261
2) Add comment and describe what happens
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 16, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
I need trippers for an Intermatic Raintight Outdoor Timer model HB11R
1) Intermatic trippers: Buy Amazon or Intermatic store
Copy following link to identify tripper
2) Copy following link to identify Intermatic analog timers with replaceable trippers
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
3) Add comment and describe timer in detail, and color of tripper
Dec 10, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
How do you wire a Toro Rain Sensor 53769 to Intermatic Timer T8845PV
The rain sensor only connects to Intermatic sprinkler timer IF the timer has the rain sensor terminals.
Not all Intermatic sprinkler timers have that connection.
For example R8815P101C and R8816P101C have rain sensor terminals
I think the rain sensor terminals are located to the right of main wiring terminal block.
There are two screw terminals.
The rain sensor plugs into a power source, and then sensor wires connect to the timer.
Apply no voltage to the sprinkler timer terminals.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
May 01, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Have a woods 1875 watt timer how do I program it
Woods timers are shown on this page:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
https://www.ccixpress.com/webapp/wcs/stores/servlet/ColemanProductGroupView?catalogId=10101&storeId=10051&productGroup=Lighting%2FTimers%2FControls&langId=-1&bu=&channel=%24&customer=
Scroll down to bottom of page where it has links to indoor and outdoor timers ... open those links to find your timer ... site has pdf manual for each product listed.
If you still have a problem, re-post question with specific model and type of timer.
Sep 15, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Lost setting instructions for Intermatic timer model: HB800RCL. Need help..
I have located a site which has the instructions for your timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb800r.ashx
I located this while searching for an image of your model timer
Jan 30, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Describe your Intermatic & Indoor/Outdoor Rain Tight Timer Problem I have the model T104 I think, stamped E10694 on it. I can set the start/stop but it does not come on, I have...
is the dial turning, or is it in the set mode, were its not engaged. if it does turn are the trippers tripping the levers. if everything is working make sure the trippers are not bent, this will keep it from engaging anything.
Aug 02, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
I have an Intermatic 24hr. 125V timer, I need the wiring diagram
It should be on the door. It's marked 'line' & 'load'. Line is un-switched coming in and 'load' is your output to your motor or whatever you're running.
Jun 26, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
106 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
