Question about Philips DVDR3455H/37B
Dvd drawer will not open. just shows blocked - Philips DVDR3455H/37B
My 3 yo daughter was very rough on ours. I replaced the belt on the drive with an "o" ring after it continually showed "blocked" and I was away again. You could probably pick one up from your local electronics shop.
Posted on Jul 21, 2009
Hi, I need a pioneer dvl-909 service manual that tells how to replace the loading belt. Thanks, Bill
Try to see if the drawers are blocked by something either inside or outside of the case.
Mar 17, 2012 | Pioneer DVL-909 DVD Player
I recently acquired a used Dell Optiplex 320 desktop computer. When I lay the computer flat, the dvd drawer will open and function. When I stand the computer upright, the dvd drawer will not open. I am...
Sounds like there's something stuck inside the DVD drawer that blocks the drawer from opening if it's not its side. Try turning it over onto the other side, just for a minute, and see if it opens. If it does, there's something blocking the drawer. If it doesn't, you'll probably need a new drive, as that one's literally worn out...which I've only seen twice.
Jul 04, 2011 | Dell Drive for Dell OptiPlex 320...
I have a dvd player daewoo dvg 8500n and don't work on region 2. thanks
Open the drawer and LEAVE IT OPEN
Press 1379
Four star will show up on screen
Press 0
Close drawer with control
Press play
Feb 14, 2011 | Daewoo DVG-8500N DVD Player
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
Disc drawer will not open with either the button on the set or the remote control. Display shows "open" the changes to "no disc"
Jan 19, 2010 | Televison & Video
Disc drawer says BLOCKED and will not open. No disc is inserted
I had the same problem . I had to take the outer casing off and was able to open. to keep this from happining again I always leave a disc in the disc drawer it seems to solve the problem
Mar 07, 2009 | Philips DVDR3450H DVD Recorder/HDD...
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
The drawer on the unit won't open.
When the DVD player is plugged into power and switched on, and won't power up (nothing shows up in the front display panel), the power supply unit in the DVD is blown. the noise that player made was probably a capacitor going off. You will have to get the unit repaired.
Jul 28, 2007 | NexxTech DP3222 DVD Player
Philips DVDR3455H/37B Logo
703 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
