Question about Furuno Navnet 1964CBB/NT vx2 Radar C Map Nt
I have a vx3 furuno and my sounder w/ 1kw transducer reads and marks the bottom great. once I get past 1300 ft the sounder will read the bottom the the depth number is not right. I fish in 1800 to 2000 ft but the sounder unit thinks it is in 1500ft I have check gains, units of measure 50mh and 200mh . I have used this machine for years with great proformance but this week the machine will not read acturately past 1500 ft. any ideas its sounds unreal but the machine will not read past 1500ft it thinks it is in 1500ft marks the bottom looks right but its is deeper. please help
  • John Barry
    John Barry May 11, 2010
    this sounds suspicious, the transducer may have something growing on it or hanging from it. Is the picture scrolling when you experience this or is it frozen?
  • John Barry
    do you really mark the bottom at 200 feet but it is still reading 1500 on the digital readout?
4 Suggested Answers
TechnoMarine
  • 132 Answers
SOURCE: Furuno Colour Video Sounder FCV-68 tech diag need.
most are available from furuno, but not FCV 68 are you sure that is the model #?
Posted on Jan 15, 2010
TechnoMarine
  • 132 Answers
SOURCE: furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
Posted on Jan 16, 2010
TechnoMarine
  • 132 Answers
SOURCE: i have a furuno fcv 585 and have an airmar 1kw
no, the ducer should have the diplexer built in to it.
the matching box is for bare wire ducers.
Posted on Aug 04, 2010
Which version furuno echo sounder will work with the LS8000 in-hull transducer. I need to upgrade but the transducer is built into the hull, would be easier just to keep it
I think for this one your best bet would to be to call Furuno tech. directly. They'll be more than happy to upgrade your instrument.
There are two numbers:
Camas, WA 360-834-9300
Denton, MD 410-479-4420
Hope this is helpful.
Oct 06, 2014 | Boating
Good day, I just bought a transducer (R209) for my 1920 C furuno display but seem to have a probleem with the setup on the display. I have no radar connected to the system and to do the installation...
If you just have the transducer and no network sounder youre pretty much dead in the water. along with your transducer, you will need either a BBFF1 or DFF1 sounder. Since they operate on a network they will have to be configured depending on your setup.
Oct 07, 2010 | Furuno NavNet vx2 1920C GPS Receiver
I have a gps Map 498-depth sounder not working? Have new transducer from Garmin-it flashes "00"-it is not connected to boat yet (transducer)-need it be or can I put in a bucket of water (need it be in...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
May 16, 2010 | Boating
Can not get clear reading of bottom when travellling over 9 knots
Your in hull ducer is getting turbulence. (in hull or not) A transducer will stop working is the tiniest cabitation or air bubble interferes. If possible, relocate the ducer. If you have a transom mounted ducer, try angling the leading edge up. This is a 90 % chance caused by turbulence on ducer. The other possibility, al;though remote is that you alternator or ignition system is interfering after a certain RPM on the motor.
Try first to manually gain the FCV620. You will always need to manual gain set the unit if you have an in hull ducer.
Mar 02, 2010 | Furuno 520 Ihd Adj In Hull F/ 6000 600l...
I can never read the fish on the screen of my sounder whether is in auto or manual mode (yes we are catching fish)
perhaps someone has messed with your sounder settings. You may want to factory reset the sounder from within one of the menus in your navnet. Also you may have a transducer going bad. Did you hit anything with it or run aground once? Maybe someone painted over the face of the transducer with bottom paint. There's alot of things that can cause this to happen. It would be best to have the sounder checked out before you do anything to the ducer. Remove your navnet and sounder and take it to a dealer to test on the bench. If you're in the maryland area, Mid-shore Electronics and handle this for you. Even if you're not, you can send the units to them.
Dec 31, 2009 | Furuno NavNet vx2 GP1720C GPS Receiver
GP700F Airmar P66 to TM260
you must run 50KHz for deep water, so you will have to solve the interference problem to benefit from the power
Oct 12, 2009 | Furuno GP7000F/NT GPS Receiver
Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Jul 26, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
I have a furuno fcv 585 echo sounder with a FURUNO CA50/200-12M -c13298 BRONZE THRU HULL HIGH PERFORMANCE TRANSDUCER. The transducer has 4 wires and it looks from the schematic that it attaches via a...
you need an MB1100 matching box has the 10 pin pigtail for your sounder and accepts bare wire input from your ducer
this will also ensure that all power from sonar get to ducer, but it from me if you like 847-746-0100
Jul 09, 2008 | Furuno FCV-582L GPS Receiver
Depth sounder problem
If the transducer is mounted off of level, an error is introduced due to angle. It is a fixed percent offset, say 10%. so 10 feet reads 11 and 100 reads 110. There is an offset function to read depth below ducer, depth below keel, and depth below waterline, but these are fixed amounts in feet, not a percentage. Look at the transducer when it is operating, boat angle considered.
Jun 18, 2008 | Furuno GP1650DF GPS Receiver
Installation furuno GP7000F/NT
This unit has built in sonar, so no DFF1 is required. The 1KW transom mount is in stock here, with the proper Furuno 10 pin connector. That is all you need, the display, the power cord, the GPS antenna, the transducer and THE BOOK! We are a Furuno dealer in the Great Lakes
Mar 03, 2008 | Furuno GP7000F/NT GPS Receiver
Furuno Navnet 1964CBB/NT vx2 Radar C Map Nt Logo
44 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
David Burbee
David Burbee
Are you a Furuno Boating Expert? Answer questions, earn points and help others
