Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
C2424 "Printhead stuck in the tilted position..."
Hi Experts,
My system error code 07,010.43 apparently means the printhead is stuck. I need some help to get at the printhead, and some advice as to how best to clean any spilt solid ink off the innards if I find any there, which I'm assuming I will.
Anybody got a service manual or any tips please?
Thanks for your help,
mousemusic
    President:
  • 2,072 Answers
Send me an E-mail at rak458@aol.com
Posted on Jul 02, 2009
System error # 07,010.43:27456 on a xerox c2424 copier
The printhead is stuck in the tilt position, need to replace the process motor camshaft kit, part number WCC2424-Z2
http://www.iteminconline.com/wcc2424-z2_wcc2424-z2-xerox-workcentre-c2424-process-motor-camshaft-kit.htm
Jul 07, 2015 | Xerox Office Equipment & Supplies
Tip
8400/8500/8550/8560/8860/C2424/8560MFP/8860MFP Homing the process gear
Hey guys this is a video tutorial that shows you step by step how to fix the error codes, on the machines that are on the title. Some of these errors are:
  • 7,007.49: The process motor stalled while tilting the head
  • 7,008.41-43: The head tilt is not engaged, or the printhead is stuck in the tilt position by the tilt arms.
  • 7,009.42: The printhead is tilted back but not properly restrained in the park arms.
  • 7,010.43: The printhead is stuck in the tilted position, or is not tilting properly over the CAM, due to problems with the process motor gearbox.
  • C3T Strip flag time-out during transfix.
http://www.youtube.com/watch?v=oGKg-HLXGpA
on Jan 16, 2010 | Office Equipment & Supplies
Even after numerous on off sequences I still get the same error code of xerox phaser 8560 error code 07 010 43.22845
7,010.43:
The printhead is stuck in the tilted position or is not able to tilt forward to the print position, due to problems:
Has ink spilled ink around the printhead that prevents it from moving to its center position? You should be able to push the printhead right to left. Clean the printhead area. Is the printhead stuck to the Wiper Blade? Check the process drive gears for obstructions. Ensure the gears are correctly aligned and homed. Has ink spilled on the Head Tilt gear drive train? Clean the gears area of ink.
Has
Has
Apr 23, 2014 | Xerox Phaser 8560DN Printer
07,010.43 indicates the printhead is stuck in the tilted position, or is not able to tilt forward to the print position. This is a problem that I would recommend you have a Xerox Certified Technician check and repair. (This is not a do-it-yourself type of repair)
Feb 19, 2014 | Xerox Phaser 8560DN Laser Printer
System error 07,010,43:141137
That error signifies that the printhead is stuck in the tilted position, there's a problem with the cam or the pivot plate. It can be fixed by replacing the camshaft pivot plate kit, part number WCC2424-Z1.
Jan 21, 2013 | Xerox WorkCentre C2424DN All-In-One Laser...
Error code 07,010,43:37631
That error means that the printhead is stuck in the tilt position. Probably a broken camshaft, or pivot plate, they come in a kit, the part number is WCC2424-Z1. Replacing that part will fix that problem.
Jan 17, 2013 | Xerox WorkCentre C2424DN All-In-One Laser...
The process motor has stalled while moving the Printhead.
You need to check the wiring to the printhead for proper routing.
Then, remove the printhead and check for ink spills in the tilt and drive gears.
Then, check the gears in the Process gear drive train are correctly aligned, in the coerrect home position, and not damaged.
You might need to replace the Process gearbox.
May 25, 2010 | Xerox C2424 Copier
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox C2424 Error: 07.010.44:152562
Hi design811:
Here is your problem.
1. Reboot the system.
2. Did this correct the problem?
Go to Step 2. Complete.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair or
replace the lock
arms.
3 1. Is there spilled ink around the printhead? Clean the
printhead area.
Go to Step 4.
4 1.
Check the process gearbox for obstructions
or damaged.
2. Ensure the gears are correctly aligned and
homed.
3. Verify the process shaft and drive module
shaft are at their home positions.
4. Did this correct the problem?
Complete. Go to Step 5.
5 1. Verify the headtilt gear will engage. You can
manually set the headtilt gear.
2. Is the gear engaged properly?
Go to Step 6. Set the headtilt
gear.
6 1. Use service diagnostics to run the Tilt Axis
Drive
test.
2. Did the test fail?
Replace the
process
gearbox.
Go to Step 7.
7 1. Use service diagnostics to run the Process
Motor
test.
Replace the
process motor.
Go to Step 8.
8 1. Use service diagnostics to run the Head
Maintenance Wiper Clutch
test.
Replace the
wiper drive
clutch.
Go to Step 9.
9 1. Ensure the wiper is properly aligned.
2. Use service diagnostics to run the Wiper
Drive
Test.
3. Did the test fail?
Go to Step 10. Replace the
exit module
assembly.
10 1. Use service diagnostics to run the Load
Maintenance Clutch
test.
Inspect the maintenance drive
system, replace any defective
parts.
Hope this helps
May 21, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Error code 07,010,43:13829 xerox c2424
Hi sales1stsupp:
replace the lock
arms.
printhead area.
Go to Step 4.
or damaged.
homed.
gear.
Drive
test.
Replace the
process
gearbox.
Go to Step 7.
Motor
test.
Replace the
process motor.
Go to Step 8.
test.
Replace the
wiper drive
clutch.
Go to Step 9.
Drive
Test.
exit module
assembly.
Maintenance Clutch
test.
parts
Hope this helps
Apr 22, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
237 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
