Question about Garden
I have an old model victa rideon with a peerlss transmission that locks up and is almost impossible to get in and out of gear. Is ok when engine not going and after startup will go into gear once only and then jams. Hope you can help regards Don
  • donbell97 Jul 01, 2009
    Have checked inside and changed oil all seems ok and gears engage easily but not so when engine is running Don
    President:
  • 1,383 Answers
First check in gear box change oil.
Check there that gear stopper is not broken.
Also check your cluthc is working correctly.
There must be some issue with in gear box something is broekn or faulty check .
Also check gear shaft it is in gear box.
Posted on Jul 01, 2009
  • kishor
    kishor Jul 01, 2009
    check clutch system.
2010 holden cruze diesel. stuck in park, keys are stuck in ignition. have no brake tail lights no windscreen washer 12 volt socket in car and the boot is locked. please help.
The stuck in park is easy disconnect the linkage at the transmission and move the selector red by two notches (by hand) this will place the transmission in neutral if there is resistance chock the wheels release the handbrake and rock the car ( back and forward to take load off the parking parking pawl which is stuck) no electrics is because of the ignition position remove the ignition switch from the column this isolates from the ignition lock and manually move the slide until the engine starts (make sure the hoot & hand brake are applied in case you ******* up the selector job and left it in gear. once the engine starts reconnect the transmission linkage. restart the engine and run the selector through the gears if all is OK.either cut the old ignition lock off the steering column and replace or get a locksmith to remove the key and then re-cut a new key from the spare or from the manufacturers code. all done
Mar 19, 2016 | Holden Cars & Trucks
4wd light flickers but no 4wd on isuzu trooper 3.1 conversion
no YEAR, now that is a challenge.... impossible...
conversion what does that mean, a modification
car is not stock? we cant do custom cars, that be impossible.
that takes genius level hands on work.
is this PART time 4wd
or that TOD systems....
by what method did you prove 4wd works (the lamp means nothing to me, only real live 4wd actions matter)
the dash cluster if it has this wild looking 4wd graphics, that be TOD. got that?
part time only works in ice/snow/dirt.
and never on dry pavement free of ice.
so are you testing on dirt? (off road, anything)
you can also do some test on jack stands
check front prop shaft ,see if it is locked up in 4wd, engine off
but you never said what transmission.
ok a/t in park. 4wd engaged.
or m/t in any gear, 1st gear best.
if that test passes, the we check that the front axle locks up.
1 step at a time.
but i dont know what you have there "full driveline option specs"
Oct 08, 2015 | Isuzu Trooper Cars & Trucks
How do i set the timing of victa altima lawnmower,i just want to know where the mark of crank shaft and cam shaft must point? it is a one piston engine with two valves
There is a mark on crank gear, and there is a mark on cam gear. These two marks may be a circle, a dot, a triangle or possibly something else. The idea is two marks must be placed together for gear timing to be correct. I hope this is what you are asking. Please let me know how you make out. GOOD LUCK FRIEND.
Jan 10, 2015 | Garden
Victa.two.stroke.wont.start
www.victa.com/au/support-centre/owner-guides
check spark.
If ok. chec for fuel inside on plug. If ok
check compression of engine.
Oct 12, 2014 | Garden
Alko concord t11-75
Look under shifter linkage for a cotter pin that connects shift lever to transmission. If this is out or linkage is bent this could be your problem. If these parts are ok you most likely have internal damage to transmission.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 04, 2013 | Garden
Victa Turfmaster gear selector. I have had the mower back to the dealer three times to fix different aspects of the selector mechanism.
How old is the mower? If its under warrenty, I'd request a new selector completely! Is it commercial or residential grade?
Sep 24, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
I have a victa corvette cox made ride on mower
Being cox made I'd go looking for cox manuals for the same era. Victa just rebadged others mowers.
Nov 18, 2009 | Garden
Starter motor on rideon mower keeps snaping plaste gears
Use OEM Briggs & Stratton gear specifically for your model number engine and be sure you install the gear with the bevelled edges of the teeth UP
Sep 09, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Makis- is it possible to get 'taller' 4th and 5th gear -stwdst
Changing FINAL drive easy with chain or belt drive - difficult/impossible with a driveshaft. Final drive affects all gears/engine speeds.Possible aftermarket "taller" 4 & 5 th gears available, but not likely.Another/similar model have the same transmission? Is the bike made in a touring ("open road")model? Touring may have taller gears.Perhaps different ratios/gears from another year of same model.Good independent shop may have knowledge of this situation -if a fix is available.Dealers - likely not
Jun 12, 2009 | 2002 Honda VT 1100 C2 Shadow Sabre
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
