Question about Corona 23-DK Compact Heater
Electric starter I bought my unit used. I can't tell how to make the electric lighter work.
  • eridon Oct 08, 2008
    I bought my DK 23 new, and had no problem with it for years. Recently, it was time to put in a new wick; and now I can't get it to start. I probably did something wrong, but I don't know what I did.
    When I push down on the starter, the little coil lights up, comes forward and down, but I don't see any sign of the wick. I know that I put it on right, but maybe I did something wrong when I put the parts back together?
  • eridon Oct 10, 2008
    Now that I have taken my DK 23 apart several times, with each new piece of information from half a dozen websites including Corona USA, I am convinced that the wick is in correctly down to the exact 2 and 1/4 inches between the top of the wick and the pins in the sleeve. The knob is also working perfectly. So is the coil, but the coil appears to be too far away from the wick to light it. Last thing I heard from Corona is try lighting it with a match, and if it still won't light, the kerosene could have water in it, in which case forget the whole thing. So far, I have not found the right kind of matches at home so I have to go out and see if I can find long ones.
  • 3 Answers
Do not use a match to light your kerosene heater. For one, basic kitchen matches are too short and put you in a dangerous position during lighting. Yes, they make long matches, but that brings us to reason number 2. The head of a match has a tendency to fall off and could foul your system.
If you just can't get your electric start to work and you need to use a flame to ignite your heater, go to the grocery store and buy a package of bamboo skewers. They are cheap and you get dozens in a pack. Light one end of the skewer and use that to ignite your heater. After its lit, the end of the skewer can be cut off and reused. A single bag of skewers will last a really long time.
Posted on Dec 05, 2008
    Problem Solver:
  • 10 Answers
You can light the wick with match or one of those Bic BBQ lighters.
Posted on Nov 21, 2008
I have a different make and model, but many of these use a similar design. A battery pack (2 x D or C cell) is mounted on the kerosine tank. The batteries are used to heat a coil. The coil is pressed by an external button against the heater wick. Pressing the button also engages the switch, heating the coil until it glows red hot.
1. Open the burner chamber of the unit and confirm it has a wick installed (this is a used heater--who knows it's condition). Close the chamber.
2. Make sure the tip-over protection hasn't retracted the wick. Generally the tip-over protection is reset by a lever on the base of the burner.
3. Adjust the wick all the way up. A knob on the base of the burner does this.
4. Fully depress the electric starter until the coil touches the wick.
5. When the kerosine on the wick ignites, release the starter and adjust the wick to the desired level.
If the electric start coil does not glow, check the batteries. If the batteries are good, the starter coil may be bad. These are also
Posted on Nov 09, 2007
Call your provider, the only one who cen tell you how you can get authorized warranty service.
Please remember that Fixya is just a Q/A aforum and this kind of issues are our of our knowledge
Jun 04, 2015 | Kitchen Ranges
My vibe 2004 doesn`t start sometimes since I start using fm transmitter powered by cigarette lighter outlet. When I start,i hear a little click but starter doesn`t come on. After waiting for 20 to 30mn or...
it could be the the starter solenoid or starter itself that is the said it started when you started using your fm transmitter have you tried not using it to see if it starts working correctly for a few days.if it works normally then this is the problem.try another outlet if you have one to see if the problem starts again.
May 25, 2011 | Pontiac Vibe Cars & Trucks
Have 1986 toyota sunrader camper. Stove lights up
The small jets at the end of the tube are probably plugged, Remove the jets and make sure you can see through them. if not then you can use a small wire to push any foreign object out of the hole.
Mar 26, 2017 | RVs
Recently bought iPhone charger and hands free connected to cigarette lighter in J31 Maxima. Fuse blown after 12 hours use. Fuse replaced but blown again. No previous history of this.
check to see that the lighter fuse or accesory fuse is the right should tell you on the cover of the panel if it is to low that could be causing it to blow otherwise you have something in ligter plug or charger unit causing a short
Dec 30, 2009 | 2005 Nissan Maxima
Trying to install narva driving lamps unit has
In 12 volt DC automotive electrical systems black is always the ground wire or negative. Make sure you disconnect the battery before doing any electrical work (unhook the negative cable first). Don't splice into any wires under the dash, use a piggyback fuse connector on one of the accessory fuses eg; cigarette lighter.
Sep 20, 2009 | 2008 Toyota RAV4
I used another charger in house and charged battery must be the car charger adapter I haven't used it yet but I will today and let you know if it works
Jul 24, 2008 | Garmin StreetPilot C330 GPS Receiver
My lighter plug in doesn' t work can You tell me wich symbol has the fuse in the box?
since your lighter plug in has stopped working, has any other interior electrical equipment also stopped working, like the coutesy light for instance, or the car radio etc?
May 23, 2008 | 2006 Honda Accord
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Sportster 4 not working...
I had the same issue. This is what Sirius calls a "Frozen Unit". There is no bypass, unfortunately, and it must be returned.
I had mine for 3 days and it froze on the Sirius Logo screen when booting up. If you bought the unit from Sirius, you must contact their E-Commerce department. If bought from a retailer, take it back to the store.
Sorry, mate.
Oct 13, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Corona 23-DK Compact Heater Logo
214 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
