Weather King 12AJA4801AH Air Conditioner
Problem for Weather King 12AJA4801AH Air Conditioner
Condensor fan runs after compressor shuts off
By rwhitmore on Jul 01, 2009
I replaced the condensor fan and now the fan will keep running after the compressor shuts off. I could use a schematic showing the correct way to wire the condensor fan.
Best Solution
posted on Jul 01, 2009
Helpful)
daddyo742001
Rank: Wiz
Rating: 84%, 27 votes
If new motor is 4 wire verses 3 wire use seperate capacitor between brown wires and don't use terminal on 3 pole cap. If this motor has a white strip on one brown wire you can wire it the old way using only 1 brown wire and tape off the other. Can't remeber this morning which brow wire to use . I need to leave. Goole replacemotor with 2 brown wires for more info or call where you bought it. Sorry got to run.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Weather King 12AJA4801AH Air
Questions and Unsolved Problems for Weather King 12AJA4801AH Air
Do you recommend Weather King 12AJA4801AH Air Conditioner?
Answer
Answer
I have a SHARP AY-a249J system that starts cooling for about 20-30 minutes then the cooling system... (More)
Answer
Answer
turned off my furnace to change filter and it wont come back on.
Answer
My model number is not recognized but the correct one is WSKA-A024JK 000
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Weather King 12AJA4801AH Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
