HP Teaming Software
Teaming nic's on Proliant DL 585 G2 and Proliant DL380 G2 using Win2003x32 and x64connects then drops after re-boot. Teaming and nic's show connected but I cant ping the DG or hit the internet on other servers on same subnet. Tried using the onboard nics as well as some intel 7170 PCI nic's, same issue. I have updated to the lated nic drivers and teaming software. We have not had this issue on any of the older 585's or 380's.
  • Anonymous Mar 27, 2008
  • lsosa33 Dec 02, 2008
    I have a HP DL380 G4, I have a similar problem, when I team the onboard dual nics using 802.3ad (switched assisted load balancing). The NIC teaming works just fine, but as soon as I reboot the server the team nic looses it configuration and no longer can communicate with other computes. The icon on the lower right hand corner of my desktop indicates that it is acquiring an IP address, If I open the properties of the teamed interface, it shows the static IP address information, but if I use IPCONFIG from the command prompt it shows that there is not IP address. I can fix the problem by disabling and enabling back the teaming interface.
    I called HP and they had me try all kinds of settings as well as different version of the NIC driver and NCU. At the end they said that it was a known issue with windows OS (I am running 2003) where the TCPI stack loads before the interface is ready, causing it to loose the IP address. The patch that they recommend applying did not work as it said that the version of the installed patch was newer that the patch I was trying to install.
    Reloading the OS is not much of an option for me as this is a production (exchange) server. So far nothing has worked.
  • 131 Answers
You might have forgot to configure your preffered dns servers on the lan properties, that is why you are not able to ping the other systems.
Posted on Jan 05, 2008
  • M Karthikeyan
    M Karthikeyan Jan 05, 2008
    check out your default gateway also
HP Compaq ProLiant DL380 G2 Server won't boot from cdrom
Hello, I think you might find more information on starting up the DL380 G2 at the link shown below:
Also, the replacement instructions, in case it needs to be replaced, (and relevant troubleshooting info) for the 5i controller are found in the link here :
Please first make sure that you are using the proper startup boot disk for the server before entering the CD ROM option from the boot menu. Also, check the front panel of the SCSI drives for any errors or blinking LEDS that correspond to an error code. You can run a diagnostics CD/DVD that arrived with the manufacturer's pack to detect any raid issues on startup.
If you are still facing difficulties with booting up the server, you can find a video for replacement of the appropriate scsi drive here if you are still facing any issues of your scsi drive. Try a different hard disk or check the relevant diagnostics to verify whether is the controller or the drive that complicates the booting of the server
For more details check the scsi manual in the link below (section "FBWC LEDs" , pages 15-17).
May 18, 2012 | HP Compaq ProLiant DL380 G2 Server
Compaq Proliant ml370 g2 does not boot, beeping every 30 seconds, no video output. Internal Health LED is RED, Harddisk Health LEDs all green Component Health LEDs all green (RAM Banks are...
hdd fault caused by surge video card failure ram failure hdd failure depends what the beep codes are they are coded the length and duration tells you what the fault is ie three short beeps or two long ones try bleeping or check out bleep codes
Apr 28, 2011 | HP Compaq ProLiant ML370 G2 Server
USE441A02R-ProLiant DL380 G4 HP NC7782 Gigabit Server Adapter IF we select 1000MBS it failes to connect n/w, But we select 100 MBS it will resolve
I have the same problem and have seen two possible options for resolution...try updating the NIC's firmware and it could be a motherboard problem that needs to be replaced by hp. If either of the options provides the solution, let me know. I'm in the midst of it. (I've tried updating the drivers, swapping network cables, even feeding the NIC a known connection that gives 1Gbps.)
Aug 13, 2010 | HP Compaq ProLiant DL380 G4 Server
How do i boot a compaq proliant dl380 with a usb drive set up for booting?
Make sure you have turned on the USB Boot in the BIOS of the os. Once this is done, select the order you would like for the server to locate boot files. (Hard Drive, USB, CD/DVD, etc.) Once complete, insert the USB and reboot the server.
Good Luck
Jun 30, 2010 | HP Compaq ProLiant DL380 G2 Server
Looking for replacement card for Nic integrated PS2, Video and Ether
The server could not connect to the network. The network and its cables are all okay.
Feb 02, 2010 | HP Compaq ProLiant DL380 G2 Server
Hp DL 380 G4 no display on screen, all the status lights are green
We had the same problem with a G5 version of the dl380, no video at boot or OS boot. This model fortunately had another video out on the front panel that worked. However, I believe that the G4 does not have that option coupled with using the Rage XL's from ATI for video. Have you tried installing another video card into the expansion slots for video? If you are able to, you may find that when you run your smartstart and load/reload the OS your video will work with the onboard.
Dec 03, 2009 | HP Compaq ProLiant DL380 G4 Server
I have an old hp dl 380 G2 that will not power up it was unplugged for a coupel months I get amber lights but nothing happens when I hit the start button would dead battery on motherboard cause this?
The amber clearly states there are some problems with the hardware. Either with the power module, CPU or memory. Try contacting the vendor and get it repalced.
Dec 02, 2009 | HP Compaq ProLiant DL380 G2 Server
DELL DL-380 G5 "could not allocate page table memory" GSS 2.5
First of all, Dl380 is an hP product.
Secondly your ghost version seems a bit old as ghost 14 is the latest version. Having said that the problem could be at two ends.
1. At the ghost side where your version doesnot contain NIC drivers for PXE boot and HDD drivers for imaging. To fix this you can try manually adding the drivers to the network boot or floppy boot diskette.
You can get the drivers from HP website or the PSP CD that came with the server.
Alternatively you can upgrade to RDP instead of GHOST, RDP is Symantec's offering sold by HP for imaging it's servers.
2. There's some problem with your NIC settings or card if you are trying to PXE boot.
If you are using a floppy drive/ usb HDD, check from BIOS if it is detected.
Jun 25, 2009 | HP Compaq ProLiant DL380 G4 Server
Problem with DL380 G4 after reboot
do you use software/hardware raid?
hopefully hardware :-)
and is it mirrord or raid5?
Jan 26, 2008 | HP Compaq ProLiant DL380 G4 Server
Boot problem with a ProLiant DL 380 server,
To enter the BIOS of a ProLiant DL380 you have to press "F9"
Jan 23, 2008 | HP Compaq ProLiant DL380 G4 Server
Computers & Internet Logo
1,376 people viewed this question
David Payne
David Payne
