Question about Zebra 110Xi III Plus Thermal Printer
Zebra xi III Plus printing shadows and blurred text on labels. Initial printing was fine but all prints now have a shadow and blurred text.
  • 2 more comments
  • adelinek Jul 01, 2009
    What should I check specifically? Unfortunately I don't know much about printers. I've looked at the printer config and compared it to other Zebras and it seems ok. I've replaced the ribbon but this has no effect on the problem. Any help would be appreciated. Thanks.
    What should I check specifically? Unfortunately I don't have any experience of these printers. I have checked the printer config and compared it against other Zebras and it looks ok. I've also replaced the ribbon but the issue remains. Thanks.
    Printer head pressure and toggle position needed to be adjusted to correct and resolve this issue.
  • techvinny666 May 11, 2010
    Check your printer settings.
I changed the printhead and now the display is not displaying any data, only light.
Posted on Apr 22, 2011
    Scholar:
  • 111 Answers
Try adjusting your printhead. If that doesn't work you might need to replace.
Please contact me if you have any question or if you come across needing a printhead for your unit.
I carry all parts for that printer in stock .
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Posted on Jul 10, 2009
Zebra TLP 2824 Plus does not print barbell labels
You need to run win7 in XP mode. I am not sure the Zebra software will run in 64bit.
Feb 27, 2017 | Zebra Office Equipment & Supplies
Good morning, having problems with zebra printer 110xilll Plus. white streak down middle label. V
You can try cleaning the print head with Isopropyl Alcohol, if this doesn't fix it - you printer will require a new Print head
Jan 20, 2010 | Zebra 110Xi III Plus Thermal Printer
Zebra Xi III
yes .. the print heads can be calibrated to compensate for cold labels or you could just warm them up .. if they are really cold then it takes longer to expose the image .. if you dont compensate for that then the letters will not be fully developed (grey)
Nov 23, 2009 | Zebra 170Xi II Thermal Printer
We presently have a Zebra 110XiIII Plus Printer that we use for printing labels containing Text and Bar Codes from an MS Access based application. Our current printer comes with a Roll of paper, and labels...
@ gould804.
I have the same model printer and utilizing it the same way with text and bar code. My issue is not the the font but rather the text is not printing, only the bar code. Maybe we can contact and work with each other to resolve both of your issues. let me know?
Nov 19, 2009 | Zebra 110Xi III Plus Thermal Printer
Want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
May 04, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Hi, I have a zebra 110 xi||| plus which is printing extra labels.
Did you design the label? Do you have any control over the label design? This is usually a sign that the printer is trying to excede the page limit (usually by one dot row) and is going to the next label to finish. By making the label length slightly smaller, you can stop this.
Mar 20, 2009 | Zebra 110Xi III Plus Thermal Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Only printing 1/2 a label
recalibrate the printer in the set up.
Don't just do a quick cal from the front panel.
Make sure your driver is the correct dpi zebra driver, either zebra or my preferred seagull scientific.
by .5 of the label, do you mean width or heigth.
If it is heigth, check to make sure you are set for top of print correctly. Also you will have to back feed for a label that short.
Feb 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Zebra 110xi plus not printer strainght across label
* do full manual calibration
* reduce the print speed & try
* set back feed as before instead of default
* try with little big labes
Jul 28, 2008 | Zebra 110Xi III Plus Thermal Printer
Zebra 110Xi III Plus Thermal Printer Logo
273 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
