Question about HP Computers & Internet
After a break in power computer will not switch on.Green light at back is dim and blinking.what is the solution?
  • 144 Answers
Id make a sensible guess that you might need a new power supply. Please give the make and model of the HP computer and i can find you a replacement :)
Posted on Jul 01, 2009
Can not get my tail lights to work onk 1989 gmc truc
The front park lights work correct? If the front park lights work than there is not a problem with the light switch since the brown wire from the switch supplies power to the front park lights, front side markers, and the rear taillights. There should be twelve volts on the brown wire from the headlight switch with the connector plugged in and the park lights turned on. If this is true that there is a problem with the wiring to the back of the vehicle. A thorough inspection of the harness should reveal the problem. The dim break and blinkers support the above. High resistance also know as corrosion, in the wires or connections would cause this problem.
Aug 24, 2012 | 1989 GMC Sierra
Blinking green light
I get a blinking green light in my freezer when a piece of ice gets stuck instead of dispensing into the ice bucket. First break the stuck ice off then there is a switch beside the green light that you turn off then back on. You should be go to go again until the next time. Mine does it alot and I have a friend with the same refrigator and the same continous "stuck" ice.
Jun 25, 2012 | GE GSH25JFT
Dim green light on power supply blinking
If the Power supply LED dims and flickers its either your motherboard circuit has been cut or there is a short in the laptop. The AC adapter is not the cause.
Try this:
Remove the battery, then press power button to drain all the current, then re-install battery and plug to adapter.
If that doesn't work, then it's most likely the motherboard.
Mar 19, 2012 | ASUS (X83Vb-X2) PC Notebook
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
Front lights ( Dims ) come on when I press break pedal
Sure sounds like someone transposed the power leads from the brake peddle and the light switch - or the ground is bad - and a back feed of power is causing this.
I suggest pulling the Headlight fuse to determine if that feeds the head or brake lights. Same with the brake fuse.
Ground feed back is most likely and most difficult to identify. A bad connection to ground - somewhere - can do some weird things to lights.
Oct 13, 2009 | 2000 Ford Focus
Will not pwer up. Greenlight blinking on back
The green blinking light can mean there is a problem with the power supply.
Try unplugging the computer from the wall, and turning on the pc on switch.
After a few minutes, try plugging it back in.
If that does not start things up, you may have a bad power supply.
If the power supply is bad, these models take standard power supplies. You should get an ATX 350Watt or higher power supply.
They are easy to replace, unplug the power from the wall, disconnect all the cables inside the computer. Unscrew the four phillips screws outside the back of the computer where the power supply is attached to the case.
Remove and replace.
If you don't feel comfortable with this, a good local computer shop can help you out.
Apr 13, 2009 | HP Compaq Presario SR1330NX (PP161AA) PC...
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Hp Pavillion a420n blinking light
Hello!
Is the pc has blinking power in it. or do your hear any beeping sounds? but anyway you can do check your PC. unplug the pc and open the system. remove and clean the memory and insert it again. and fix all connection inside the pc maybe some cable lessen. after that test the pc. and then tell me what happen i will give you more solution in it. melnavz
Mar 25, 2008 | HP Pavilion a420n PC Desktop
Computers & Internet Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
