Question about Samsung SGH-E900 Cellular Phone
Pairing passkey what is the passkey to pair my sgh-e900 wth vaio vgn -tx26gp_w please
  • liud60 Jul 01, 2009
    Thanx,unfortunately 'unable to connect' again
  • 1,800 Answers
Try eight zeros
Posted on Jul 01, 2009
  • Jalal Sordo
    Jalal Sordo Jul 01, 2009
    at leat give a feed back poeple!!!!
I need the passkey to pair my nokia 6350 bluetooth with my cellphone. I do not have the passkey. Please help
When you are pairing any two 'smart' devices, such as phones, computers, and such, i.e. devices which act as bluetooth 'hosts', in the device which you will use to start the pairing process, you can choose any digit sequence you can think of (e.g. you can specify the most common passkey used by 'dumb' devices, i.e. 0000 (four zeros)), provided that in the device which is receiving the pairing request, i.e. the other 'smart' device of yours, you specify that same passkey. You don't need to worry if the passkey you choose is too simple (like the one I've suggested above), because, once the devices are paired to each other, all subsequent connections between them will be encrypted.
I apologize if I havn't made myself much clear here, since english is not my natural english.
Anyway, please, let me know if I can help you out any further.
Regards, Carlos
Jul 20, 2011 | Cell Phones
What is pairing code for vgn-bms33 sony vaio bluetooth mouse?
According to the Sony website (see direct link below) the instructions say to "not use passcode" when pairing. The link is to the adobe pdf installation page so if you follow it step-by-step, you should be up and running under two minutes.
http://www.docs.sony.com/release/VGPBMS30.pdf
Thanks and hope this helps :)
May 15, 2011 | Sony VAIO VGP-BMS33/B
Nedd the passkey to pair to my blackberry
Problem :
Passkey to pair
Solution
PUT THE HEADSET IN PAIRING MODE
The headset indicator light will be steadily lit in purple when in pairing mode. To place the headset in pairing mode:
If the headset has never been paired with another device, simply open the headset boom. The indicator light becomes steadily lit in purple.
If the headset has previously been paired with other devices, first ensure those devices are turned off.
Then open the headset boom and the indicator light flashes in blue. After about 5 seconds, the indicator light becomes steadily lit in purple.
DEFAULT PASSKEY is 0000 (four Zeros)
Rate my solution please
Aug 19, 2010 | Motorola Mobility H700 Wireless Headset
When i try to pair it the bluetooth and my phone wont pair!!!The Bluetooth device is the HS820
Follow these steps to pair your phone with the bluetooth device.
Pairing
With the headset and phone close together:
1 With the headset off, hold the Multifunction Button until the LED remains on (about 5 seconds).
2 Perform a device discovery from the phone. For details on device discovery for your phone, refer to the phone’s user’s guide.
When the scan is complete, the phone displays the devices found.
3 Select the Motorola HS820 from the discovered devices list and confirm following the on screen prompts.
Action
4 When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone.
The device ID is now stored in the phone’s memory.
Pairing is successful when the headset indicator flashes rapidly.
If helpful, please rate this solution.
Thanks
Apr 12, 2010 | Samsung SGH-e315
How to pair my blackberry with SGH-T919 asking
just type anything you want.. then type the same passkey at the other phone..
Feb 03, 2010 | Samsung SGH-G600 Cellular Phone
I need to know the Bluetooth pairing code for a Samsung SGH-E900 Cellular Phone
When you are pairing with another phone, you set your own code, which is then requested from the other phone user.
If you are pairing with headphones or a handsfree unit these sometimes have their own pairing code which will be defined in their user manual.
The defaults are usually 1234 or 0000. Try these, if you have no luck consult the documentation for the device you are pairing with.
This code isnt defined by the phone
hope this helps
Dec 23, 2009 | Samsung SGH-E900 Cellular Phone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
What is the passkey to my sony vaio laptop VGN-CS160J
If you have a blue tooth device added to your laptop or build into your laptop, you will have to enter control panel and select Classic View at top left and then select Blue Tooth.
Once you are in that option window you should go to security and set your passkey there and then. When you apply your settings and return to Pair your devices you only need to use the passkey that you have entered at your blue tooth security and you should be all sweet.
Aug 23, 2009 | Sony VAIO VGP-BMS33/B
I need a password for a plantronics sgh-a767 to
Passkey refers to a password needed to connect a Plantronics Bluetooth headset to a Bluetooth device. For most Plantronics products, this passkey is 0000.
Hope this help you
Aug 07, 2009 | Plantronics Cell Phones
Samsung SGH-E900 Cellular Phone Logo
57 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
