I am trying to remove the side cover from a Dell Dimension 3000 to replace RAM. Don't seem to be able to work it out. Can you help please?
  • 25 Answers
Can you move the little black lever on the back by the PCI cards? I seem to remember it moves upwards to unlock the side. Once you've moved that, the side slides back a couple of inches and then lifts off. Put the Dell flat on its side so you can get more purchase to push the side back - it can be hard to start off.
Good luck,
mousemusic
Posted on Jul 01, 2009
  • 144 Answers
Hello
Please use the following link to view the manual for your computer
http://support.dell.com/support/edocs/systems/dim3000/en/OM/j6758A04.pdf
Page 50 describes in detail how to remove the cover and pages 53-56 show how to install memory
Please Rate my solution if you found this helpful!
Kind Regards
1234s282
Dell Dimension 3000 blue screen error with writing that say attemp to fix windows
First try to replace ram with known good one.. if you have two eject one and vice and versa.. run system to see if it's working.. if it doesn't then try to install windows on it.. If it's not Harddrive bad sector that has corrupted your windows. .It would be either RAM or a virus...
Mar 27, 2013 | Dell Dimension 3000 PC Desktop
Unit came with 2 256 mem sticks--bought and installed 2 1GB sticks(pc3200,400mhz,84pin,low density,DDR--unit will not boot
The 2 1Gb RAM are either the wrong type or they are incompatible.
Try to use the same brand and speed as the 256 Mb RAM that was installed in your Dell.
Jul 31, 2010 | Dell Dimension 3000 PC Desktop
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
RAM
You may have bad or incompatible Ram . Verify that the memory you have is compatible. .
Machine name: Dell Dimension 3000
CPU options: Intel Pentium 4 or Intel Celeron
Chipset: Intel 865GV Chipset
HD Bus: Ultra ATA/100
Front Side Bus options: 800MHz FSB
Memory Speed options: PC3200 DDR400 184pin SDRAM DIMM
Special notes: The Dimension 3000 has two different bus speeds each of which takes different memory. You cannot mix the speeds.
Take the memory out and install one at a time. This way you can verify that the memory is indeed working. If you find a bad one, replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2009 | Dell Dimension 3000 PC Desktop
The Cover on my Dell Dimension 3000 will not come off. It seems to be stuck. It will release just a little and it will not slide off. I am destroying the cover. I tried what "teeters" suggested with no...
Pull the tab down on the back right (as you look at the back) and hold it down, slide the side towards the back and lift up... thats how your ment 2 get it open....
Let me know...
Matt
Jan 21, 2009 | Dell Dimension 3000 PC Desktop
Trying to get cover off 3000 pc desktop
Hello!
PLease look in the bottom of the cover there maybe locked clip that prevent the cover to open. you should push it to unlocked the cover and slide it.
melnavz
Mar 04, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
89 people viewed this question
Alun Cox
David Payne
David Payne
