Need to find out where to buy a light switch
Not sure which model scooter you have got. But this site gives a comprehensive list of parts you can buy on line. Select your model and look for Handle Bar switch. This should include the head light switch if that is what you are after.
TaoTao Electric Scooter Parts ElectricScooterParts com
SOURCE: Where is a battery located
The batter is underneath a panel with four screws (1 recessed) located underneath the mat where your feet go.
SOURCE: I have a taotao 50 scooter nd i got water n the
Easy fix. Take the intake flexible pipe from the gas tank and drain out the fuel. .Then remove the carburetor bowl. Used compressed air to clean. Remove the spark plugs individually an blow compressed air back through the pistons. Add a starting accelerant to dry the heads. Add new gas with a clean up solution for the gas. start and run. Fare well.
