Question about Cell Phones
User manual for: BK600 Bluetooth headset.
Desperately seeking a user manual for a Bluetooth headset. MFG part# BK16 BK600. The earpiece unfortunately, didn't come with any added information, but on the back of the earpiece, it reads as follows:
BK-600
167293 FCC CE
Made in China
The device has 3 buttons on the front; 1 bigger one on the top and 2 smaller ones on the bottom area {on the front} in a vertical position. It also has a colored piece on the front part starting from top down to bottom, also surrounding all of the buttons mentioned above. The colored piece I just mentioned has kind of like an hour-glass shape to it {looks like a bowling pin shape to me}. There's also a scrible-like design right in the center; in between the lg. button and the 2 smaller ones.
Anyway, that's about all I can say to describe it, I wish I could download a pic for you. I didn't bother with the color of it because the device comes in different colors, eg. grey, red, black & clear {mine}.
Any help is GREATLY appreciated!!!
THANX!!!
SOURCE: LG bluetooth hbm 760 pin number
The pin is 0000.
Posted on Feb 24, 2009
  • 1030 Answers
SOURCE: RCA HDTV blurry
this indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
Posted on Dec 07, 2007
  • 1030 Answers
SOURCE: 3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
  • 7 Answers
SOURCE: Plasma TV technical difficulty
if you can still see the picture its most likely the control board that's going bad, you will still need a tech out to fix the issue.
Posted on Jun 02, 2008
danfrater
  • 69 Answers
SOURCE: Connect trueblue bluetooth headset to Samsung Eternity cell phone
hold your finger on the call button on your blutooth device for around 6-10 seconds, this should make a couple of lights flash, when it does this it is active and ready to pair uo, then search, it will ask you for a code, usually they are generic and are prob the following 1234-12345-1111-11111-0000-00000-5555-55555 eiter one of these should work
Posted on Jan 01, 2009
Where can I find the users manual for Sentry BT400 blue tooth earphones?
here you go. see main link
FCC ID 2ACP4BT400 Bluetooth Headset by Sentry Industries limited
https://fccid.io/2ACP4BT400
Jul 25, 2016 - FCC ID 2ACP4BT400 ( 2ACP4 BT400 ) Bluetooth Headset manufactured by Sentry Industries limited operating frequencies, user manual, ...
BT300 Bluetooth Headset User Manual Manual Sentry Industries limited
https://fccid.io/2ACP4BT300/Users-Manual/Manual-2763169 Bluetooth Headset FCC ID:2ACP4BT300 FCC Statement: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a ...
BT550 Bluetooth Headset User Manual Sentry Industries limited
https://fccid.io/2ACP4BT550/Users-Manual/user-manual-3052681 Bluetooth Headset user manual details for FCC ID 2ACP4BT550 made by Sentry Industries limited. Document Includes User Manual user manual.
BT600 Bluetooth Headset User Manual Sentry Industries limited
https://fccid.io/2ACP4BT600/Users-Manual/user-manual-3067844 Bluetooth Headset user manual details for FCC ID 2ACP4BT600 made by Sentry Industries limited. Document Includes User Manual user manual.
Free Bluetake Technology Headphones User Manuals ...
audio.manualsonline.com > ... > Home Audio Bluetake Technology Bluetake Technology Headphones BT400 G5. BLUETAKE Bluetooth Headset User Guide BT400 G5. Pages: 14. See Prices. Showing Products 1 - 1 of 1 ...
BT400 Bluetooth Headset User Manual Sentry Industries limited
Oct 17, 2017 | Radio Communications
The headset connects to the phone but then it says connecting and then comes up bluetooth connection failed and it wont work hands free, it has the blue symbol on my phone screen but wont it wont connect...
I would suggest turning off your phone and headset. Turn your phone back on and put the headset into pairing mode (the headset needs to be turned off when starting the pairing mode) pull up your menu on your Bluetooth phone and try reconnecting the two again.
Below is the Explorer 320 User's Guide for more information.
Plantronics Explorer 320 User's Guide
Good luck from Headsets Direct!
Apr 27, 2011 | Plantronics Explorer 320 Wireless Headset
PHONE WILL NOT LIFT OFF HOOK EITHER WHEN YOU REMOVE THE EARPIECE FROM THE CHARGER OR PUSH THE CALL BUTTON
It could be that the battery inside the headset is worn out, or the headset needs to be re-paired to the base unit, or the lifter is worn out. If you manually remove the handset receiver from the phone, and you power on and activate the headset, does sound come through ? If so, it may be the lifter. If not, it could be one of the other two scenarios. Here is a link for the 510S / 500A user guide to troubleshoot.
Voyager 510 User's Guide
Aug 26, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Lost user manuel. need to know how to connect to
how to connect a bluetooth to a cellphone
1. go to the menu on you cellphone and find connections-bluetooth
2. click options
3 be ready to click search for device (don't click it yet)
4. press the on button on your earpiece and hold till you get a solid bluelight.
5. when you get the solid blue light on earpiece click search for device on the phone
6. when it finds your device select it and click on it
7. it will then ask for a code or if you want to bond or pair the devices click yes and type 0000
8. it will ask you to confirm click connect
you should be able to connect.
if it works for you don't forget to rate me
thx
Apr 28, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Cant get car kit to pair with my mobile asking for code
the bluetooth default code is often a 4 digit number 0000 or 1234 if that does not work - post back the exact make and models of the phone and earpiece and I will try and find the user manual where it may mention the default code used
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Motorola Mobility Bluetooth Hands Free...
New cell phone won't "see" bluetooth earpiece
The headset will automatically pair with the last device that it was paired with. You may want to remove that just in case. I am sending the users guide along with this. Also always start with the blue tooth turned off, the pass key is 0000 (four zeros).
Plantronics Explorer 300 Series User's Manual
Feb 14, 2009 | Plantronics Explorer 330 Headset
Motorla h500 plastic earpiece his loose
Try taking it off and putting it on again. The user manual explains how to do it on the top of page two. Otherwise, it may be bent or defective.
Aug 30, 2008 | Eforcity Motorola Bluetooth Headset H500...
Cell Phones Logo
2,866 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
