Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Blades will not disengage on lawn tractor
I can't remember my model #, but I cannot get the blades to disengage. I have removed my deck and check all belts, wheels and pulleys, which all seemed fine. When I reinstalled the deck, it was better, but the blades still would not shut off.
  • gregcubbie_t Jul 09, 2009
    The model# of my Craftsman Lawn Tractor is 917.272246, it is a 20hp, 48" mower. My blades will not disengage. I replaced my PTO switch and that didn't help. I have also cleaned my deck so that it is spotless and that didn't help. I tried to attach a scanned image of my deck from the manual, but can't.
  • Dwain Pippen May 11, 2010
    Look under the seat and post the model number so I can look at a diagram of what you have....
Your cable clutch is not engaging properly. Try to lubricate it with some grease. This will get the cable to slide. If that does not help, it will need to be replace.
Posted on Oct 03, 2009
  • 513 Answers
The deck has a moving mechanism that engages the deck & disengages the deck usually the ideler pulley on left side there is a 9/16 nut on deck near pully loosen it up & it should spring back to disengage i can acually guide you better over phone its easy to fix its alot of typing if you would like call me i will guide you through it my names wade phone# is 831-578-4034 thanks wade
Posted on Jul 04, 2009
  • Roy Hollandsworth Nov 08, 2014
    I know from experience that v belts ordered for your rider mower will come in different lengths. One belt was so tight it couldn't even fit over the final pulley. I would recommend you order your v belt from the authorized factory dealer because the substitute belts seem to be joke at being the correct length and width.
Craftsman lt2000
Your blades engage with a cable and the cable somewhere is bunched up. You will probably need a new cable.
Aug 05, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Why will blades will not disengage?
check your return spring on the deck. it goes from hole in bracket welded to deck to hole in moving lever that one of the deck pulleys is attached to. if spring is missing or broke, it will not dissengage or may dissengage slowly. If spring is there, the moving lever may have debris under it or may be bent. If spring is there, remove deck and try pushing the pully with the spring to see if it breaks free.
Aug 04, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blade does not stop spinning when lever disengaged.
Under seat of tractor theres a plate that says model # it looks like 917. 000000 i need that # please and i can help you with the problem it sounds like the belt isnt disengaging which will cause blades to continue to go.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
the brakes on the deck belt not working belt to tight or deck not fully disengaging
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cutting blades won't disengage
Check you blades to see if one is bent. Do this with the mower NOT RUNNING and the KEY OUT of THE IGNITION! Look under the deck to see if one is bent. This will cause the wobble. As far as no disengaging your electric clutch could be bad. The bearing could have seized up.
Apr 24, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
825 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
