Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Vibration my mower has exessive vibration. we replaced the drive belt but not sure right size. it seems like the vibration is really bad around the clutch. if you put a little pressure on the clutch pedal the vibrating is not so bad. do you have any suggestions?
  • Keith Parker May 11, 2010
    Hi..my name is Keith..and im assuming that the bad vibration is when the blades are engaged and you are mowing..right??
I have the same mower. It had excessive vibration from the day I got it. It would also throw the belt off every time I disengaged the blades. The problem is with the electric clutch. It finally broke and I had to take it to a repair shop. They said they had seen this problem a lot on these mowers. They were able to weld the clutch and fix it but wouldn't guarantee it. It's been working fine now for two seasons with no vibration.
Posted on Jul 23, 2009
    President:
  • 1,776 Answers
This kind of problem can cause major damage if not addressed quickly. It can also be dangerous to the operator if it is caused by a damaged flywheel, so be careful.
Some things to look at are:
Damaged flywheel (missing or broken fins or blades)
Damaged or warped pulley or sprocket attached to flywheel.
Loose engine mounting bolts.
These are the areas that I would start looking at. I hope this helps you and good luck.
Posted on Jul 13, 2009
LGT 2554 belt keeps coming off ,two belts gone ,seems to be tension spring keeps throwing it , i really don't no these mowers are bad for this problem and no fix in sight Husqvarna
It would be helpful if you could provide some pictures so I could see what it is doing. Generally the belt will be thrown off if it is badly worn and hence it is loose, so a replacement might fix the problem. You should also make sure that it runs correctly around all the pulleys as it is easy to get one wrong, finally make sure that all the grass has been cleaned from the tensioner and around the pulley guides, and that the pulleys are not badly worn. If they are badly worn, the belt will sit in the bottom of the pulley instead of on the sides, and will throw off really easily. A damaged belt will also cause it to be thrown off.
May 05, 2018 | Husqvarna Garden
Poulan PO17542LT riding mower, the main drive belt broke and I am trying to replace it. However, everytime that I put the belt back on I get a terrible vibration from the belt and then it pops off.
Check to see if one (or more) of the pulleys are bent. Also check the engine drive pulley to see if it is bent.
Does the vibration happen if the clutch is engaged or released?
May 02, 2017 | Poulan Garden
Have greenfield fast cut 34 mower replace drive belt but have problem going forward up hills clutch is worn half mm could clutch be glazed
Are you sure your new belt is the proper length A quarter inch too long could make it slip. Something to try is spray your belt with belt dressing and see if that helps That will help stop it from slipping.I had to do that with one of mine when my belt was not the right size. I shot spray about once a week one summer.
Dec 07, 2014 | Garden
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
May 19, 2014 | Craftsman Garden
1997 MTD Riding Mower 18hp 42"cut. Drive belt
I wish to tell dwhandys that this is a great answer, and a great solution. You surely know how to work!
Sep 03, 2011 | Yard Machines Garden
How to tighen the built on a Troy Built Pony 42in Riding lawn mower
You can't really tighten the belt on any of these mowers.
First make sure you have the right belt, if you measured the old one when it broke
then you were not using the size it was before it got all stretched out from use. Find a manual
or look around online for a source to tell you the size the belt should be new and get one.
Second there is a tensioner arm, spring, and pulley which take up the slack, this may
double as a clutch to put in slack when you depress the pedal. Make sure the pivot for the
arm, the spring, and the pulley/bearing are all in good shape.
Third there are belt guides which can also be worn and create slack, so check those and make sure
they are in good shape as well. I may not be the only one who ever put a belt on the wrong side of a guide.
Lastly make sure you have the belt on correctly, and nothing is bent, split, or warped.
May 03, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Steps needed to change transaxle belt
lift the front of the tractor up at least 3 feet and lower the mow deck to give you clearance. push the clutch pedal and lock it down to release belt tension. remove the mower belt from the engine pulley only. remove the trans belt from the idlers about midway back then from the trans pulley & finally from the engine pulley. put the new belt around the engine shaft above the mower drive pulley but not on the drive pulley then around the trans pulley. now you can put it on the drive pulley and finally on the idlers. make sure you have it under all the various keepers or the belt will shred in like 10 minutes. release the clutch pedal & check the belt again to ensure it is in the correct place. replace the mower drive belt & ensure that didn't come off other pulleys in the process. lower the front of the tractor and test
Oct 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 17hp lawn tractor shutters bad when releasing the clutch pedal. is it the clutch and where is it located?
Its not really a clutch, clutch/brake pedal when pressed will release belt pressure which stops pulley from turn axle. When predded all the way down it mechanically applies brakes. The vibration is from a bad pully that the drive belt rides on or a bad belt. Look for chucks of belt missing.With engine off put on parking brake and manually wiggle each pulley that drive belt rides on to see if there is any play. No play should be present. Good luck.
Mar 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Clutch vibration and jerking at slow speeds.
Check the drive belt. It probably has chunks missing or at least has flat spots (narrow spots) that cause the belt to jump every time it goes around a pulley. That will set up a heck of a vibration. Also check the pulleys for free movement. The drive belt is above the blade drive belt....
Jul 27, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
931 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
