Question about Natsume Harvest Moon: Friends of Mineral Town for Game Boy Advance
Closed Shop! I have the same problem! Spring of Year 3, my supplies, bushels and other stuffs, are depleting. I don't know what to do.. every time i go to any shop.... It always says "counter"... I experienced this kind of problem for two weeks in the game... Please help me.. My sheep and cows will gonna die... Huhu...
  • 58 Answers
Check your time
Posted on Aug 05, 2009
I am trying to buy a hog feeder and it says it holds 1.5 bushels of grain how many pounds it that? Thank you Denise
difficult to work out
1.5 bushels volume =12 gallons volume = 128 lbs mass
the difficulty is that a bushel is a volume measurement and as can be appreciated a bushel of oats will have less mass than a bushel of wheat even though the volume is the same
by converting to gallons and applying the mass of water (10lb to the gallon) as a base line , the result is as close an approximation that you will get
Of course a simple method would be to simply weigh the bushel of what ever you have and read the mass directly off the scale
Dec 14, 2017 | Kitchen Appliances - Others
How may pounds is 11/9 bushel
Pounds of what? The weight of a bushel varies with the commodity in the bushel. Go to this website and you will find the weights of various items in bushel:
http://www.alpharubicon.com/primitive/bushelssitkastan.htm
Find the commodity,then divide the weight by 9 and multiply by 11.
That's your answer.
Aug 31, 2015 | Cars & Trucks
How do you know when thermastat needs to be replaced
Well, your car either over or under heats. A thermostat can fail in any position, open, closed, or partial.... They are fairly cheap, so many times it is just replaced, even as a diagnostic step.
This is the time to get the cooling system flushed. The new stuff, red, gels up as it gets old, have a lube shop do the flush, they can contain the old stuff and dispose of it properly.
Some thermostats are in somewhat fragile housings. Just be gentle. Get all of the old gasket off, if yours has a gasket and not an o ring.
Oct 27, 2012 | Pontiac G6 Cars & Trucks
Automatic foundation vents
You never know how long they will last. They don't always work like there suppose to - buy manual - you know they will be opened & closed according to the time of year because you have to do it yourself.
Sep 25, 2012 | Cars & Trucks
Tried to fill up full tank in 2007 chevy cobalt ls and it wont take anymore than $1.00 before the fuel nozzle clicks and spills gas all over. anyone know what's up?
Hi, sounds like your vent valve is stuck closed. It is supposed to default open, but the spring may have failed. I don't know if you can buy the valve separate from the vapor canister assembly, but I would shop around. The guy at the following post was having trouble finding one: http://www.cobaltss.net/forums/problems-service-maintenance-69/evap-vent-solenoid-100807/
Oct 07, 2011 | 2007 Chevrolet Cobalt Coupe
Can I change my ac compressor on my 98 dodge ram 1500 myself. Concerned about refilling and air in the system.
Replacing the compressor is strictly a mechanical task but recharging the system isn't and if there is still coolant in the system, it shouldn't be vented into ambient air.
Although Dupont managed to get the old coolant type banned, they only did it so they could sell us the new stuff (R134) which, for some reason, ALSO says on the containers that it STILL shouldn't be released into the atmosphere. The whole change was a scam perpetrated on us by collusion between the EPA and Dupont.
Apr 05, 2011 | Dodge Ram 1500 Cars & Trucks
Wiring diagram 2003 GmC Sierra
I need wiring digram for GMC 2003 SIERRA . I have the left head light working fine but the right I have no power to it. I have checked the fuses and relaysand so far have not found and broken or frayed wires.
May 12, 2009 | 2003 GMC Sierra
Door sensor broken?
Sounds like you, indeed, have a broken door latch. If the latch is not able to lock successfully, it will not go into any wash cycle and will exhibit the symptoms you are describing. The door was designed to be closed gently, not slammed or forced. To replace, you will need to do the following: 1. Unplug the machine. 2. Remove the bottom kick plate. 3. Remove the rubber door boot from the around the door opening. There should be a wire hoop holding it into a groove with a small tension spring located at the bottom of the door opening. Feel around the rubber lip and locate the tension spring. Stretch this spring and pull the wire hoop from the groove. 4. Remove the rubber boot from the outer seal and push towards the inside of the wash tub. This will give you access to the inside of the machine casing. 5. The door latch is located inside the casing on the right hand side. There are three screws holding it in from the outside and a wiring harness and retaining clip holding it from the inside. Use care when removing the wires from the old latch. The wires are small and can break. I hope this leads you in the right direction. Let me know if you need any further advice.
Jun 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Natsume Harvest Moon: Friends of Mineral Town for Game Boy Advance Logo
81 people viewed this question
Top Natsume Video Game Consoles & Games Experts
James Wishart
Are you a Natsume Video Game Console and Game Expert? Answer questions, earn points and help others
