Question about Timex Advanced Data Link 53722 Wrist Watch
Replaced battery in lorus digital watch, now the alarm won't work
It seemed fairly straight forward, the watch battery had been dead for ages and I finally got round to replacing. It was a case of unscrewing the back cover then unscrewing a plate that held the battery in place, swapping the battery for a new one, then putting the plate back on. I shorted the ac terminal with the positive side of the battery and then put the back cover on again, only to find the alarm beep wasn't working. The alrm test and also when using the stopwatch it would normally beep when pressing the buttons but it doesn't make a sound.
I tried shorting the ac terminal again, this time I kept it shorted for about a minute, and it did work, the time reset, but there was still no sound.
  • 7 Answers
The alarm spring proabably was lost. If it was, it will not alarm again.
Posted on Aug 27, 2009
I need to change the time on my lorus digital watch
Try Googling (lorus)(model)(manual) without parens for instructions.
Apr 01, 2018 | Lorus Watches
I have a Lorus LQQ603S-A and I need to know the battery size
Take your Lorus watch to a jeweler who will demonstrate how to open it and identify the battery type. The jeweler may even be persuaded to replace the battery for a reasonable sum.
Feb 20, 2018 | Lorus Watches
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 | Watches
Need to replace battery of lorus mickey mouse pocket watch
Try to find a watch repair shop (sometimes called clock & watch shops). Also, many jewelers replace batteries and do watch repair.
Jan 13, 2011 | Lorus Watches
I just bought an older Lorus Disney Mickey Mouse Musical watch V422-0010 with a box behind this number thia square was around the letters ZO. I cannot get the watch to work. It says, "After installing...
There is no CR920 3 volt battery and especially will not work for any Lorus watch. There is the SR920SW and SR920W series 1.55 volt silver alkaline cell.. 9 mm diameter x 2.0 mm height is an impossible size for this old Lorus watch.
Jan 02, 2011 | Disney Lorus Rare Musical R2306AX Watch
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
Dec 17, 2010 | Disney Lorus Out of Production Collectible...
How to set the alarm on the lorus rf33bx9
If you put "lorus watches" into your search engine you should come up with the Lorus web site.
One of the options given is "instructions", click on this and you will be asked to enter details off the back of your watch.
Feb 11, 2010 | Bulova Watch
Cant get old watch to chime
Instructions are on the inside of the back cover: 1. short circuit AC and the battery clamp. 2. the hands will rotate once clockwise 3. in the chime mode, pull out the crown and set the hands to the 12:00 position 4. Return the crown to normal position, change to time mode and set the desired time
Jul 06, 2009 | Disney Lorus Rare Musical R2306AX Watch
Can't get to work.
I have a lorus rvs001. Silver with black band. The instruction booklet says it takes a SR920W. Seiko Maxell or Sony.
Apr 13, 2009 | Watches
Timex Advanced Data Link 53722 Wrist Watch Logo
679 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
