Go to Settings > Connections > Bluetooth. In Android Pie, tap Advanced. ... Turn on the Dual Audio toggle switch. To use Dual Audio, pair the phone with two speakers, two headphones, or one of each, and audio will stream to both.Feb. 4, 2021
Note that you will not be able to implement it via Bluetooth, because Android devices does not have the function of audio stream broadcast to multiple devices at ...
If you have purchased Speakers with Bluetooth Connectivity capability you can do this by switching on the speakers and on your iphone use the Bluetooth Pairing Option from Bluetooth settings to establish connectivity and play music to hear from speakers
pretty simple, turn it on for radio, hold mode utton for 2-3 seconds to switch to speaker mode. if u turn it off and turn it again on, it will always start in a radio mode! thats all
To Pair: 1. Turn on your Bluetooth speaker (slide switch to BT) 2. Light on bottom should turn on Blue. If not, plug speaker into USB connector and bottom will turn Red to indicate it's charging. 3. Make sure Bluetooth is turned on your PC or Phone. Select device name: CMA3532BT. 4. Enter pairing code (passcode): 0000 or you can try: 1234
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
For PSP Go owners, a very cool feature is the ability to pair
bluetooth devices with the system. This recipe will show you how to
toggle between outputting audio between the PSP Go’s speakers/headphone
jack and a bluetooth headset/speaker.
1. Pair your bluetooth device with your PSP Go.
-Go to Settings > Bluetooth Device Settings
-Be sure to turn the Bluetooth Connection ON. Then select Manage Bluetooth Devices.
-Click on Register New Devices; put your headset into pairing mode and pair it with the PSP Go by following the onscreen prompts.
2. Once your headset/device is paired. Be sure to leave the Bluetooth Connection on.
3. Finally, open up the music player or a game and when you want to switch between the PSP Go’s speaker or your headset, just hold the Audio button on top for about 7 seconds. It will change the volume icon w/a bluetooth icon and audio on your PSP Go should start outputting via your headset.
To toggle back to speakers/headphones, again hold the audio button for about 7 seconds and it will switch back.
This should work with any bluetooth headset and does not require it being a stereo headset (ie any $5 headset should work).
i got the same problem...what a POS phone, also sucks for text messaging. if you switch to speaker phone u can have your convo, but i have a loud car and cant hear speaker, need the earpiece, but its totally dead :(
