How do I winterize a 2013, nomad joey select, 207
Assuming you mean you're going to park it for the winter ????
Start by draining all the water tanks, i.e., fresh water, grey water, black water. Go inside and open all the faucets - if you have one or more where it's a common lever type valve and you swing it left or right depending on desired water temperature, then set it for the middle and turn it full on - leave all faucets turned on - shower included. This will allow the water lines to drain out. DO NOT TURN OFF the faucets - leave them on. Don't forget the toilet tank. If there is still some water left in the bottom of the toilet, pour in a cup of standard automotive antifreeze (ethelyne glycol type) and then CLOSE THE LID of the toilet. Ditto this (antifreeze) for all of your drains. Pour 1 cup of (full strength) liquid antifreeze into all drains (sink drains, shower drain, etc) Finally, make a sign that says "WINTERIZED - PLEASE DO NOT USE" and then TAPE THIS onto the toilet lid.
