Question about Fagor Washing Machines
Hi, Using programme 4 - the cycle seems much faster than it used to. The initial wash is over very quickly and then it moves on to a rinse. Whole cycle is complete in about 30 mins! Might this be early signs of the programme switch failing?
    Genius:
  • 1,239 Answers
Hi this is the timer problem,,,i think u didnot adjust the timer or the control pannel is the problem,,,
please check it
thank u,,,
Posted on Jul 01, 2009
Hi we moved to a new flat with a kuppersbursbuch iwt 1259.2w washer. we cleaned the filter and put in a dettol detergent to clean it-since then it pauses mid-cycle and does not pump out the water
It is doubtful cleaning the filter and using Dettol will have caused any problems.
I believe it was quite common to have a programme where the washer stopped mid-rinse before pumping out the water in order to reduce creasing of the clothes. The programmer would be advanced when it was convenient to do so and the rinse cycle would continue and finish with the final spin.
I suggest you read the instruction manual before deciding whether there is a fault or not...
Mar 05, 2017 | Washing Machines
Dead Washing machine
seems issue with the control panel. try unpluge the unit and pluge back after 10 min and chk.
Aug 12, 2008 | Washing Machines
Hello, I have a beko WM5120W Washing Machine, and when I try to use the quick wash programme, it does the washing cycle ok, but when it starts the rinse programme, it pumps the water out ok, but when water...
hi
the water level switch or sensor does not activate to tell the programmer that there is plenty water so that it can start to rinse ( what you doing is simply overriding the system .
Dec 31, 2017 | Washing Machines
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
The rinse cycle no longer works
Likely the balance sensor is failed - or the motor controller itself.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Washing Machines
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
AWM1404/4 whirlpool skips wash programmes
try some wd40 spray around timer shaft.but yot may have to replace the timer hope this helps.
Mar 19, 2008 | Washing Machines
Washing Machines Logo
98 people viewed this question
Top Fagor Washing Machines Experts
Vernon Taylor
roeb
Are you a Fagor Washing Machine Expert? Answer questions, earn points and help others
