Question about Gestetner Office Equipment & Supplies
Gestetner 3245 dev.bias setting....
I have gestetner 3245 copier it has a lighter copy before but i change the dev. bias setting to 700v the default is 600v now my copier copy gud... can any1 give me feedback about dv bias? wat is the disadvantage of it i change the setting... ..
  • thraser
    thraser Jul 05, 2009
    wat u mean adjust the laser power up wer can i find it? wat is the short cut key ( short cut key i mean just like if u initialize dv -short cut key is 2805)
  • 313 Answers
Hi how you doing the main problem with changing the dev bias is that the gap between the drum charge and dev bias has been brought closer and so more toner is being put onto the drum for image density.. I take it you have cleaned the optics on the scanner mirrrors and that the laser **** glass has been cleaned as these effect the copy quality too.. if the dev hasnt been changed at the pm intervals it slowly looses its charge holding capabilities.. you should change at least at the 160k marks to keep quality good.. you could also adjust the laser power up so you have a stronger image formation..hope this helps..if you know the machine I would take the laser unit out too and take the cover off to see if there a dust coating in the image mirrors as this can cause faint copies over a long period.. Good Luck A
Posted on Jul 01, 2009
Canon ir 2016 the copy is very light I put the brightness to the end of darkness and still the problem the copy is very light this problem appear when i change the fuser film
this has nothing to do with the fuser film .check the dev bias strip on the door ,u might have damaged that while changing fuser film. also take a report from the menu and see whether that is also light . if that is also light then the problem is either the dev bias strip or dirty laser. if the report is ok then clean the optics.
Sep 28, 2011 | Canon iR 2016i Black and White Copier
Gestetner 3235 copier speed only 35cpm it true that
replace the board and the main motor and the polygon mirror motor( not recomended)
3245 45cpm
3235 35 cpm
Oct 30, 2009 | Gestetner Office Equipment & Supplies
For ricoh copyar
to change these settiings you will have to enter the service mode .. to do this press the yellow clear button then type 107 then hold down the stop[red button] hold this down for 5 secs and the screen should change select copier sp mode and then item 2 drum the charge settings are the first selection usual setting is 900 by making it higher you will make it lighter..you can also check the dev bias this should be 550 by making it lower it will make it lighter also.. before you do these changes make sure you have cleaned the exsposure mirrors and the laser lens glass if on you copier tis will be on the panel above the drum or under the dev unit
Jun 07, 2009 | Ricoh Aficio 1035 Copier
Hw many grams dv is needed in afficio 450 or gestetner 3245
I just responded to your other thread, sounds like you are trying to use a generic dev, or something. You are asking for big trouble.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Gestetner 3245 get lighter wen run 50 to 100 pgs
the amchine runs a density patch every 50-75 prints if you run long jobs it cannot run patch till job is finished which is why your copies get lighter the longer the job
Jan 14, 2009 | Office Equipment & Supplies
Gestetner 3245 copy machine
You have a problem in the heater, sensors detected temps over 220c for more than 6 seconds. It will be an expensive repair. Most likely around $400 parts plus labor. Not something for the average Joe to troubleshoot.
Aug 21, 2008 | Gestetner Office Equipment & Supplies
81 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
