Question about Yamaha RX-V663 Receiver
How to start a dirt bike?
I dont know how
  • 67 Answers
Use the kick start
Posted on Jul 01, 2009
Dirt bike wont run. I have replaced the stator and pickup coil, the regulator, grounded out the neuatral safty switch, and bypassed the kill switch. I get a great spark about every 6 to 10 kicks
7 Things To Do When Your Dirt Bike Won't Start - All
www.instructables.com/.../7-Things-To-Do-When-Your-Dirt...
InstructablesSometimes when your dirt bike does not get used, it won't start.Here are some ways to start a "mad motor."
What To Do When Your Bike Won't Start - Dr. Dirt - Dirt Rider ...
www.dirtrider.com/features/protips/141_0803_dr_dirt_bike_wont_start
Apr 6, 2009 - Tech How-To****There are few things more frustrating to a rider ready to ride than a motorcycle that won't start. But a silent machine need not ...
So, Your Dirt Bike Won't Start? - Cannibal Cycle
Dec 15, 2015 | Motorcycles
Tip
How to change rings in a 2-stroke dirt bike.
Hi there, ok first off pull everything like the gas tank and seat and if you have to, the rumber plates. Then take the exhuast header off, next, you want to take the spark plug out and then if u can ok the coolent core, undo the coolent hose, (if your dirt bike is on a stand) put ur dirt bike in the highest gear as possible and slowly turn the wheel backwards and antifreeze should come out, once empty put bike back in N and losen the bottom bolt in a star patteren. and after that take the bolts all the way off, then get a rub malet. and lightly!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! tap it once on each sid and the top end should come completely off. After that take the rings off and start with the part of the ring, with the pin in the piston. And the ring should pop right off. then reverse the steps. NOTE: when put the rings back in and u start ur bike up, dont rev it paast 500 rpms (until after break in) (break in is less then half throttle for a gas tank full to empty)
on Aug 17, 2010 | Motorcycles
I have half a float in my pit bike carb how do i start it i cant find another float all that matches the shape of the half one that is in my bike already it is a triangular shaped black plastic or rubber...
You can't run that with half a float. A float is a part that is specifically designed a certain way and size to match the needle . If your float is wrong it will either open to much or not enough the needle valve causing a flooded carb or a carb with not enough fuel to run. I'd check eBay for one or find find a matching carb on eBay ( make sure the mm's are the same as far as the intake side and exhaust side and if the throttle cable slide is in the same location it will work.if its one of those funny named Japanese bikes like a bms or sum thing they got a bunch of those on eBay .
Jul 30, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
Should you start on a dirt bike or street bike?
That depends on what you are using it for. Obviously, if you are dirt biking, you should use a dirt bike, and otherwise use a street bike. Start out with what you are going to use the most - dirt (freestyle) or street racing.
Dec 16, 2010 | Cycling
DONT KNOW THE YEAR OF MY DIRT BIKE
do a vin check with a dealer but make sure you get all the numbers mine is an 1981 yz 250 and it only has 8 digits the dealer didn't know **** call the maker of your bike
Apr 04, 2010 | 2003 Yamaha YZ 125
I left the bike in my garage and now it wont start, what could i do?
hi friend,
Move switch to ON position
Locate your dirt bikes OFF/ON, RUN/OFF, or START Switch. Use your finger to move the switch to the RUN, ON, or START position.
  • Step 212233_65x95_aspect.jpg Turn fuel switch ONLook on the side of your dirt bike near the engine and locate the "FUEL ON/OFF" switch. Use your finger to move the lever to the "ON" position. Your dirt bike will not start if the fuel is turned off. This off switch helps prevent fuel leaks when your dirt bike is stored.
  • Step 312234_65x95_aspect.jpg Turn choke ONIf your dirt bike engine isn’t warm, you will need to turn the choke on to start the bike. Locate the choke lever near the engine on the side of your dirt bike, probably not far from the "FUEL ON/OFF" switch. Use your finger to move the choke lever to the on position. Once your dirt bike has started and the engine has warmed up, you will need to move the choke lever to the "off" position.
  • Step 412236_65x95_aspect.jpg Foot on kick start pegBend your knee and place your foot on the kick start peg while leaning your weight on your other foot. Stand slightly and push the kick starter all the way down with as much force as you can.
  • Step 512239_65x95_aspect.jpg Push all the way downIf the bike doesn't start after the first attempt to kick start it, try again. Remember to push the peg as far down as it will go with as much of your weight as possible.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • If your dirt bike has a four-stroke compression engine and won't start, release the compression valve and try starting it again.
    • Sometimes, the engine remains in a compressed position and cannot turnover until the pressure is released.
    • If your dirt bike is equipped with an electric-starter, but won't start, you can follow these steps and kick start it.
    • Remember: always wear safety equipment when operating a dirt bike or ATV.
    • You should at least wear a helmet, boots that cover your ankles, and a chest protector to avoid serious injury.
    • Always supervise children when operating motor vehicles.
    hope this helps u
    please rate me.......................
    thank u for using fixya
    regards
    sivaranjini
    Nov 30, 2009 | 1992 Suzuki GSX 600 F (Katana)
    I'm trying to find out how to set the timing on a 1999 rm250
    Stators usually do not move unless someone does it or a engine overhaul. Go to a Suzuki forum (dirt bike) and someone will have the answer. Each bike is different so it might be worth it to get a shop manual. Dirt bike manuals are all not that pricey
    Oct 15, 2009 | 2003 Suzuki RM 250
    Dont know the year or size of my dirt bike
    usually on the front fork area where the forks pivot there should be a manufacter sticker with the brand and year and most times the size also. Just a guess but my bikes have them.
    Mar 31, 2009 | 2003 kawasaki KX 250
    Yamaha RX-V663 Receiver Logo
    139 people viewed this question
    Top Yamaha Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
