My porsche cayenne gts 2009 reverse camera is stuck ,its cover is not opening when I reverse my car . kindly help.
Is the camera activating? Is the screen going completely black or do you see the measurement marks on the screen when putting it in reverse? Might be a blown fuse, faulty power wire to the camera or simply that the cover is physically stuck by dirt or something.
Testimonial: "Hi , Thanks for quick response, camera is working fine because when put gear lever in reverse the pcm screen changes and I see some light on bottom of screen as camera peeps through cover."
Then there might just be some dirt that stops the cover from opening. Try putting it in reverse with the parking brake ON, and go back and see if you can carefully get the cover to open with your finger.
tried a lot could not open. seems that motor is not getting current supply
how to physically open the cover or the motor ?
Is the camera stock that came from the factory or an aftermarket one?
stock camera , came factory fitted
