Question about HP (D7580-60003) Motherboard
USB controllers hello sir i am using windows xp sp 2 media center edition 2005 on hp a1350n.when i click on device manager i found my universal serial bus controllers disabled.is there any way to solve this problem?
  • Anonymous Mar 20, 2014
    dg31pr
  • 147 Answers
Yes enable it in bios setup or if it is enabled in the bios then enable it in device manager . Right click and click enable.
Posted on Jul 01, 2009
My hewlett packard windows xp media center edition 2005 computer does not do anything when i connect a usb cord to it
Does it work with a USB flash drive or hard drive? If not with all of those, then go to the device manager.
Right Click on Computer. Click on Manage. Click on Device Manager.
Right click on the USB driver and uninstall it. Restart your computer.
Update the drivers. You can use RadarSync.
Check if it works. If not, then comment below and I will get back to you as soon as I can.
David
Mar 31, 2013 | Microsoft Windows XP Professional -...
Can't access freecom storage USB disk
w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Hope it helps.
Dec 21, 2012 | Freecom network Media Center 500GB, Gb LAN...
Why the windows7 cannot recognize the usb cable device of psvita
w7
Oct 07, 2012 | Microsoft Windows 7 Home Premium 64BIT...
HP TSGH-IR02 Remote Control how to install
This document pertains to HP Media Center computers with Windows XP, Media Center Edition.Use this document when the remote control does not work correctly with the Media Center software.Troubleshooting the remote controlUse the following items to troubleshoot when the remote control does not respond or when the remote control does not work properly. For example, when a key is pressed the selection moves all the way to the top or bottom of a list, or moves a selection many different places instead of the item you were trying to select.Before attempting these steps, make sure that PC has been updated with all of the latest Windows updates. Many updates for Media Center, like Update Rollup 1 for eHome Infrared Receiver, can be downloaded easily through the Windows Update software Tool.
Make sure that the batteries for the remote control are installed correctly and charged.Make sure that the front of the remote sensor is unobstructed, within a 45-degree range, and is less than 26 feet (8 meters) away. Disconnect all devices that use a USB connection except to the receiver, keyboard, and mouse. Restart the PC, and then try the remote again.If a pressed button repeats itself (sticks), unplug the IR receiver from its USB connection, wait one minute, and plug in the IR receiver. If the pressed buttons continue to repeat, alter the lighting conditions in the room or move the location of the IR receiver. Other remotes and HP Media Center PCs within range can also cause this issue.Try pressing the Enter key on the remote after changing a channel.If the remote control works when using the media center software, but does not work when changing the television channels, re-configure the Media Center software settings for the cable set-top box or satellite receiver
Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the remote control (most likely the configuration of the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.
Troubleshooting the IR receiverThe IR receiver is the small device that receives the signals sent by the remote control. Use the following steps to test and reset the IR receiver.Disconnect the IR receiver from its USB port on the computer, maximize the Media Center window if it is open, and then reconnect the IR receiver. Test again.Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the IR receiver (most likely the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.Click Start , right-click My Computer , and then select Properties .Click the Hardware tab and then click the Device Manager button.Click the plus sign next to Universal Serial Bus Controllers.If the eHome Infrared Receiver is listed under Universal Serial Bus controllers, Windows is properly detecting the IR receiver. If eHome Infrared Receiver is not in the list, or there is an exclamation mark or a question mark on the device, perform the following until eHome Infrared Receiver appears correct in Device manager:Unplug the end of the USB cable on the IR receiver from the computer and plug it into the same USB port.Plug the end of the USB cable on the IR receiver into the front USB port on the computer.Disconnect all other USB devices, leave the IR receiver plugged in, and then restart the computer. Plug in other USB devices after the IR receiver shows up in device manager.Figure 1: IR receiver listing in Device Manager
Testing the remote controlUse the following steps to check the responsiveness of the remote control:
  1. Open the Media Center software by double-clicking the Media Center icon the desktop or by pressing the green Start button on the remote control.
  2. Click Settings , and then click General .
  3. Click Check Your Remote , and then click Next .
  4. Press the numbers on your remote control. The corresponding numbers on the numbers on the screen should glow when each button is pressed. A faint red light should also glow inside the IR receiver each time a button on the remote pressed.
  5. Click My control is working properly , and then click Next . Do not click I am having problems with my remote control as this will not do anything.
  6. Click Finish after you are done.
Dec 17, 2011 | HP Computers & Internet
Hi sir, I need help on my pc, i install a usb 2.0 pci to usb card on the mother board but cant get it working, i have on device manager under other devices have an exclamation mark on universal serial...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this download are drivers for VIA USB 2.0 host controller on a system running on Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows 2000/XP are not available for download. They are supplied on CD with new mainboards or available through Windows Update. This version is a bug-fixing release.
hope this helps
Jul 30, 2011 | NEC Televison & Video
USB DRIVER
You might have to re-install your "Universal Serial Bus Controllers" here is how you do that:
1.Locate "Device Manager" usually by pressing start then typing "Device Manager" into your search menu if you are using windows 7. If not then it is easily found under Control Panel.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the "Host Controller", click "Uninstall" and click "OK".
3. Repeat step 2 until all item under "Universal Serial Bus Controllers" are uninstalled then restart you computer windows will re-install everything for you.
Mar 25, 2011 | Computers & Internet
My usb port do not work. It did not recognize any devise.
hello
Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager. If you are not comfortable with advanced troubleshooting, try the steps in the "Workaround" section.
To disable and re-enable the USB controllers, follow these steps: Click Start, and then click Run.
Note If you are running Windows Vista, click Start, and then use the Start Search box. Type devmgmt.msc, and then click OK. Device Manager opens. Expand Universal Serial Bus controllers.
Note You might have to scroll down the list to find this item. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled. Check the USB device to see whether it is working.
hope this helps
Jan 27, 2011 | HP Pavilion dv7-1240us Notebook
All External storage devices "USB Device Not Recognized"
Dear Sir,madam
You have to do some steps about fixing this problem :
1: Go to Device manager by right click on my computer then manage and then device manager.
2: Go to universal serial bus controller and export it.
3: in each USB root hub right click and then properties.
4: In properties screen select power management tab and unmark on " allow the computer to turn off this device to save power ".
5: After finishing this steps in each USB root hun restart your computer and then done
Jul 24, 2010 | Microsoft Windows XP Home Edition
HP Solution Center No HP Devices Detected
Try this
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F2100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Jan 03, 2009 | HP Photosmart C8180 All-in-One InkJet...
Usb ports not working
  1. Checking USB device status in Device Manager
  1. Right-click My Computer on the Windows desktop and then click Properties.
  2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
  3. In the Device Manager list, click the + sign next to Universal serial bus controller.
  4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
  5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
  6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
  7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
  8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
  1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
  2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
  3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
  4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
  5. Follow the onscreen instructions to save the new settings and restart the computer.
  1. USB controller or root hub disabled in Windows Device Manager
  2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
  4. Click the line in the Device Manager containing the red X.
  5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
  6. In the Communications Port Properties box, click the Resources tab.
  7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
HP (D7580-60003) Motherboard Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
