Question about ViewSonic VA712 17" LCD Monitor
Im trying ti find out if my monitor is possible to fi? becauso the lcg wer broken but i tested it, then its working but the lcd wer crack
  • 180 Answers
YOU HAVE TO REPLACE THE LCD PANEL
Posted on Jul 01, 2009
Why will my computer quit receiving wifi signal
The most likely scenario is that the wi-fi access point is being obscured by obstacles such as walls. Try moving the router or the access point closer to where you usually have your laptop. You also can get range extenders or signal repeaters that will bost your wi-fi signal.
I've listed a few possible ones below.
Feb 16, 2015 | HP Lcd Monitor Software & Documentation Cd...
Can it be fixed?
Unless you can find a used or broken model for cheap with a working screen it is not worth it.
Dec 03, 2013 | Acer S202HL LCD Monitor
A friends laptop is only showing a white screen
Step 1:
Fix a White Screen on an LCD Monitor
b>When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance.
b> b> b> Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video. For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen. After I assembled everything back together and connected the original LCD, it's still white. CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced. b> b>
Feb 06, 2013 | Toshiba 16" Satellite A665S6095 Intel Core...
My Gateway FPD2275W LCD monitor has just failed.
Trying to find replacement parts for your model could be a task. LCDs are so inexpensive these days it would be cheaper to just replace it. Not sure if you have a Frys computer store nearby but I saw a 22" LCD for 129.00. Check your local electronics stores also. If you did find the part for your Gateway consider the cost and installation fees.
Eric
Oct 23, 2009 | Gateway FPD2275W LCD Monitor
Lcd monitor
Is the LCD monitor broken with a cracked screen or is it just not displaying an image?
If the screen is cracked then it needs to be replaced.
If there is no image on the screen and it is not physically broken then the fault could be an inverter problem or a faulty CCFL lamp.
For service, parts and DIY info on LCD screens check out LCD Parts, click on this link to their WEB site : -
www.lcdparts.net
Oct 05, 2009 | Sony Computers & Internet
Lcg jukebox code
http://www.crackfound.com/crack.cgi?text=lcg+jukebox&Submit+crack=Search
follow this link and download the code program. you may have to try more than one, but I use this site all the time and it works great 99% of the time.
Sep 12, 2009 | Nokia N-Gage QD Console
Unlock key for LCD JUKEBOX
Have the cracked version
at
http://teamfluxion.synthasite.com/resources/LCGJukebox.sis
If asks for serial key,
Put '0'
Please Rate
Oct 29, 2008 | Nokia 6600
T.I 84 Plus Calculator
Well, this might not be right, but check the Brightness. Hit 2nd, then the down arrow. repeat this a few times. see if that works.
Sep 14, 2007 | Texas Instruments TI-84 Plus Calculator
Broken Monitor
Hi Roeder, I have never heard of an LCD screen cracking from anything other than physical force, this is a first for me. It is possible since there is high voltage power in there for the backlight. In light of the sound I suspect a component failed, generated lots of heat real quick and caused the crack/failure. This is really unusual and you might try calling Gateway to see if they will replace it, especially if it is one year or less old. I would resist all temptation to open the LCD till you call Gateway. If they will replace it they won?t be happy to find you opened the case. Let us know how it works out and please don?t forget to rate this post.
Feb 02, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
ViewSonic VA712 17" LCD Monitor Logo
66 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
