Question about Zanussi ZWF1430W Front Load Washer
E20 flashing mid cycle - Zanussi ZWF1430W Front Load Washer
  • 725 Answers
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Posted on Sep 19, 2009
SOURCE: WASHING MACHINE FRONT LOADER
Thanks for the response for the Zanussi. Ended up having the pump replaced. Cost about £50
Posted on Feb 25, 2008
robotek
  • 1512 Answers
HI there, doing some research for you now....
Posted on Mar 10, 2008
  • 157 Answers
SOURCE: Stopping mid wash cycle with E20 showing
pump check filter
Posted on Jun 30, 2009
MsMithra
  • 79 Answers
SOURCE: e20 error code. what is that?
Read here :
http://www.fixya.com/support/t615626-error_code_e20
Hope this helps. =)
Posted on Oct 20, 2009
  • 53 Answers
SOURCE: Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Posted on Nov 01, 2009
Testimonial: "Thank you so much - exactly right"
E20 error message
maybe you should just get a new washing machine
Dec 11, 2013 | Washing Machines
Another AEG e20 Plea, tried everything please help!
E20 on your machine means some sort of drain problem. If it actually goes through the spin cycle fine; some water will still not drain out at the time of the tumble dry. Check the wall drain to make sure it isn't clogged..
Check the drain of your wall, not the washer, this shd be cleaned out thoroughly; and the exit pipe of your washer should not fit too tight into it, there shd be some space for air.
This is a further tip, if helped click helped.
Apr 10, 2013 | Washing Machines
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
Apr 24, 2010 | Zanussi ZWF10070W Front Load Washer
Error E20
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi jet system 1200
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Press "end of cycle" to finish the mid stoppage..
Rate me pl.....if helped.
Jan 02, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi error e20 then ele
Somebody suggested to me that there is a condensation tray at the back that has become blocked. He said to take the back of the washing machine off and at the bottm right hand corner there is the condensation tray. This will need de-fluffing!! I haven't tried it yet but am also looking for answers!! Let me know if you come across any other info. Pete
Jan 06, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
419 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
