Wireless networking not working any fix please thanks for last help
  • 67 Answers
If it is not working try and reset your router for 30 seconds and then manually put the router key and web key in
Posted on Jul 01, 2009
My wireless networking adapter doesnt work it shows a steady red light
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help determine the resolution and guide you to the proper fix for you Problem
Thank you.
1. sounds as if the power supply has failed. the unit device needs service.
Mar 11, 2011 | Microsoft Wireless Network Adapter Xbox...
My mad catz wireless network adapter is not working, i tried to seting it up for hours. i tried following the steps and got to the web address 10.10.10.254 but the steps still did not make it work no...
Here's a guide that shows step by step what to do.
http://www.scribd.com/doc/54198766/WGA-Setup-for-Windows
If you need more help please get back to me.
Thanks
Jan 30, 2011 | Mad Catz Wireless Network Adapter 54Mbps ...
I have a Compaq Presario CQ60 and a Netgear WNR2000. They'll connect through an ethernet cable but not using wireless. The router is working fine with other devices.
check the connections for the wireless card and make sure they're both attached, you can see where to look here
http://www.insidemylaptop.com/remove-motherboard-from-compaq-presario-cq50-cq60-cq70-laptop/
if connected make sure not a firewall issue. Try removing all wireless profiles stored in your computer and re-connect to your home wireless network, make sure that you have the correct encryption needed if your wireless is secured.
Or... Click on Start select Control Panel. Select Network and Internet option and then click the Network and Sharing Center. In the tasks on the left click Manage Wireless Networks. Click your network name in the list, then right-click and select Remove Network. This will clear out the profile. Then go back to the Network and Sharing Center and click Connect to a network and reconnect to your network.
might actually be better to start with last one first but I have one too and wireless comes undone easy enough.
hope this helps
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me
as well. Thank you
Nov 19, 2010 | Compaq Presario Notebook
XP PC connects/Vista PC doesn't/Connectivity issues
On the Vista Computer
Goto
Start>Control Panel > Network and internet > Network and Sharing center
On the Left Hand Side Click on Manage Wireless Networks
Remove your network From the List
then
Start > Connect to> Click on ur Network > Click Connect
Dec 22, 2009 | Belkin F5D7234-4 Router
Motorola SBG900 Assign network address to computer
I guess your modem router was already configured well since it worked already previously. It seems that your motorola router is set to broadcast dynamic IPs (DHCP enabled) and your last connected Pc and laptop were configured with static IP. Please check your "network connection" setting and make sure it is set to "Obtain IP automatically"
Reagrds!
Jun 30, 2009 | Arris SURFboard SBG900 Wireless Router...
Please Help -- Acer Aspire 3000 Wireless Stopped Working When I R
If your wireless network adapter is OK then :-
If your wireless connection is on the Task Bar the right click on this Icon and left click on REPAIR.
If no Icon on Task Bar the click on Control Panel - Network Connections - then right click on your LAN Connection and left click on REPAIR.
This will get your wireless router to issue your wireless card with a new IP address.
Apr 22, 2009 | Acer Aspire 3000 Notebook
Cant connect to secured wireless network...
Hi Grant,
If it says aquiring acquiring network connection while you connect to the wireless network it means that something is conflicting with the wirelss network, so first you have to check wether 2 wireless utiliies ( windows wireless utility and dell utility )are active at the same moment, if yes disable one of them and try again, still if it does not connect, disable antivirus and firewall and check if that fixes the issue, still if it does not work then try changing the security type on the routers page, basically this should work out and still if u have any issue, please reply to this msg for further troubleshooting steps....
And even if it gets resolved please reply once.
Thanks and Regards
Anup
Apr 01, 2009 | Dell Wireless 2350 Router
More help needed please!!
hi, the Broadcom 802.11g Network Adapter is your built in wireless adapter. right click that then check the status if it is working properly, it would tell you that on the status, on that you will also have an option to go and update the driver of your card.
Sep 17, 2008 | Computers & Internet
Intel 3945ABG 802.11a/g/b Wireless Adapter Problem
look in your routers settings and see if there is an idle time setting and set this to '0'
Feb 13, 2007 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
