Question about ViewSonic VE510b Monitor
Imy 15-pin vga port connecting to the monitor has 3
I have 15" viewsonic monitor (ve510b) and my 15-pin vga port connecting to the monitor has 3 pins broken. how to fix it since the cable comes attached to the monitor (unlike detachable ones that modern monitors have). pls help!
  • 158 Answers
I am sorry but there is no way to replace just the three broken pins. You can replace the entire vga plug but it requires stripping down each individual wire and soildering a new one on. You can pick up a 15 inche monitor for next to nothing. Try ebay.com you can get a nice flatscreen for a good price. I am sorry.I wish you all the luck in the world.
Posted on Jul 01, 2009
Hi i am looking for vga cable 9 Pin Female to 15 Pin Female thanks
The 9-pin port on your PC tower is NOT a video port, it is a serial data port. All VGA connectors are 15-pin. Hooking up to the 9-pin port will not get you a picture. There should be a VGA port on the PC, or else a DVI an/or HDMI port. You can get DVI-to-VGA adapters that work, but only if the DVI port is an analog DVI, not if it is a digital DVI (DVI-D or DVI-DD).
Feb 02, 2016 | LG Computers & Internet
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
Jul 30, 2014 | Proview Computers & Internet
How to hook it to an old dell comp
Just use the VGA cable (15-pin).
Monitor VGA port on the PC to the monitor VGA port.
http://www.viewsonic.com/products/va1912wb.htm
Dec 01, 2010 | ViewSonic VA1912wb Monitor
Need Cable Connector for VA902b monitor
Any PC repair shop should have this standard VGA DB15HD cable. Or just go online, it is just VGA CABLE 15-PIN/3-ROW male to male.
Apr 05, 2010 | ViewSonic VA902b 19" Monitor
Came with 2 cables for attachment - on longer type with 2 sets of pins to middle and one side and another smaller with 2 rows of pins - problem is monitor has 2 places to attach but the smaller has 3 rows...
The monitor comes with DVI and VGA (DB15HD 3-ROW HIGH DENSITY) connectors. If your PC only have VGA (DB-15HD) output for the monitor, then you need to use VGA cable (DB-15HD Male to Male) for connection. Hope I explained clearly.
Apr 01, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
Only have one serial port on my cpu can the monitor plug be switched
there could be another port for the monitor to use a VGA cable. check and see if your computer is capable of VGA from the port of the back of the computer and if it is. use a VGA cable to connect the computer to the monitor.
Jun 08, 2009 | HP Computers & Internet
Monitor says No signal digital
Is ether the monitor or video card uses both DVI or VGA port. There may be a switch on the graphic card that changes it from DVI to VGA, often outside the card.
Also is the computer monitor set to the right setting if it can use both VGA and DVI, if using DVI (of any type) it need to switch to digital, and if using VGA it need to be set to analog. This may be a physical switch or using the settings button. (see manual how to change them)
PS: VGA port is a blue D shaped port with 15 pin holes, and DVI is a white rectangle port with one port being a line.
Mar 17, 2009 | ViewSonic VG2030wm LCD Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
13pins "from the monitor" "to 15 pins VGA connector"
You will have wires of 7 colours. Solder it as per the data below...
White 7
Red 6
Black 10
Yellow 9
Blue 12
Green 1
Brown 13
The pins are numbered as follows
4 3 2 1
8 7 6 5
12 11 10 9
13
Apr 02, 2008 | SAMTRON 55V 15" CRT Monitor
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
ViewSonic VE510b Monitor Logo
298 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
