Question about Casio DR-210HD Calculator
Error When you turn the machine on it just gives me a "E" and It will not change from that no matter what key I hit.
  • 21 Answers
The problem with this is the unit's printer. It is either the gears are need to be realigned or the printer detector is defective. There is also a possibility that an I.C. on its mainboard is already defective. The best thing to do is to contact the nearest authorized service center for casio calculators. They can either render a home service or you will have to bring your unit to their service center.
Posted on May 27, 2008
Why do I have error code SC542 on richoh aficio sp6330N
542 is usually a fuser error. Thermistors. You should give your local Ricoh agent a call let a technician come and fix thermistors with new ones.
Jul 02, 2014 | Ricoh Aficio SP C231SF Color All-In-One...
Casio te 4000f use i just bought one and it gives me E194 select menu error what should i do
There is no error by the number 194 in the standard firmware. Your machine has probably had a special firmware implemented for a special use. This doesn't matter too much as they will usually program the same way for all of the usual things. Firstly, I'd perform a flag clear which will jump the machine out of any tasks that it is currently waiting on. It doesn't lose any data so it is safe to flag clear.
1. Turn the machine off at the power.
2. Turn the key to the 'program' position.
3. Hold down the RECEIPT FEED button (keep your finger on it).
4. Turn the power on.
5. After 3 seconds, let go of the RECEIPT FEED button and press SUBTOTAL once.
6. Wait for print then turn key back to REG mode.
You will need to sign on to use the machine. Normally, you press one of the clerk buttons just above the keyboard to sign on unless it has been programmed for PIN number logon (you should have been given the PIN numbers if this is the case).
Once you have logged on, try making a sale.
If the machine gives another error, check the receipt that just printed. Let me know what the number at the bottom of the receipt is. It should show 'FC' then a number.
Apr 20, 2014 | Casio Parts Cash Register PC Desktop
Rang in 3.50 customer gave $10-when you enter amt tend you get error
turn the key to program and enter (0) , cash, then subtotal . then hit 3 subtotal, (0) cash, subtotal. turn the key back to reg and the cash key should now function correctly
Jan 07, 2014 | Casio PCR-T2000 Cash Register
Kyocera KM-2050 Problem error C6400
Fuser unit Error code, you can try to reset, but if the code still there, you need to change the fuser unit.
This is the way to reset your fuser code;
On the panel press 1087 1087
this will take you to the service mode,(look into the screen)
now on the panel again press 163 and hit the start key.
Look in the screen, you will see execute, select execute by the arrow and hit the start key, the machine will turn off then on. or it will ask you to turn the main power off than on. this might fix your problem, if not! change the fuser.
Nov 19, 2011 | Kyocera Mita KM-5035 Printer
KEOCERA MITA photocopier KM4035 have problem. My Machine is showing error code C6000. How to tackle this proble. Please help me as soon as possible.
KM/CS 2530, 3530, 4030, 3035, 4035, 5035
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Press EXCUTE on the touch panel. It is displayed in reverse.
Press "Start / Print key.
The machine will turn off and then back on then come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Feb 02, 2011 | Kyocera Mita KM-4035 Printer
Canon IR1510 ERROR: E0000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. Hit Additional Functions Key
    2. Hit # key
    3. Arrow to number 7, Printer and hit Set
    4. Arrow to number 4, Printer Re-Set and hit Set.
    5. Yes, re-set printer (hit minus key - back arrow).
    6. Unplug the machine and plug it back in.
Feb 22, 2010 | Office Equipment & Supplies
Machine error. no error code.
Go into maint. mode.
With-in 2 seconds hit Menu,*,2,8,6,4
Then hit 82 when in maint mode.
This will give you a machine error code.
Let me know what that number is and I will help you with a solution.
Dec 30, 2008 | Brother MFC-8860DN Printer
Press 99 to exit Maint mode.
Konica 7020 Printer
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Konica Tech
Feb 15, 2008 | Office Equipment & Supplies
Casio DR-210HD Calculator Logo
343 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
