Question about Toshiba e-Studio 161 Copier Copier
I am getting 4 and H display - Toshiba e-Studio 161 Copier Copier
  • Toshiba Master
  • 653 Answers
H4 indicates heat lower low temperature detection. U need to perform checking on thermistor, heater lamp. If everything ok, u can use SIM-14 to clear the message.
Posted on Jul 01, 2009
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
Casio watch REM stuck display problem
Ref to link below using the module nbr found on the back cover (3 or 4 digit in a frame).
Timepieces Watches Manuals CASIO
Jul 05, 2013 | Casio Watches
Car
1. Remove two 7mm hex screws on display panel cover (top, underneith)
2. Put on parking brake, engage key (do not start), move PRNDL lever to L to get out of way.
3. Pull the bottom part of display cover straight toward you (there are 2 clips, one on either side of the steering wheel behind the display assembly cover that will snap free - takes a little force - Do one side at a time) Remove and set aside. This reveals the four display unit screws.
4. Remove the four 7mm screws on the actual display panel. (fyi: all screws in this project are the same headsize, threadsize, and length)
4. Tilt top of display panel toward you and remove the three top connectors (they come out easily and are in a cable harness so you can't put them back wrong) You will need to squeeze the middle gently, unlocking connector and pull)
5. Pull out display - which includes "glass" covering - this never gets removed! (adjust steering wheel to lowest position if needed)
6. On the rear of the panel you will see several (little grey) knobs. Find the one right behind the odometer and using a pliers, twist counter clockwise 1/4 turn and remove. The little light bulb is encased in these little knobs and is included as a one-piece replacement for the $1.50 to $4 bucks.
7. Replace bulb assembly by inserting the bulb and turning clockwise 1/4 turn.
8. Assemble following reverse instruction of above.
May 23, 2013 | 2003 Buick Century
My nokia 6300 just changed. the dispay writing is now upside down and in reverse. what is the prob and how do i get it back. i have tried restoring factory settings but no success.
You mean that it is showing you a Mirror look if like that then please refit the display. to refit your Display use the T6 screw driver to open your mobile there are 6 screw's first 2 screw's are below or back cover then other 4 screw's in front side of mobile remove the front penal then there you will get thous 4 screw's remove all 4 screw's take out the mother board after doing this remove the display shield it is metal shield remove the display with its display connector that is placed behind the Bord agen there you'll find the metal cover remove that then unplug the display with display connector and refit that on same place then refit all the things which you have removed then start then mobile it will get solved is not then you should it ones agen if your not a mobile technician then please dont try to do this.
If your not a Mobile Technician the Please Visit your nearest Nokia Service Center (Nokia Care) or Visit any Mobile Repair Center they will Doit in proper method.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Jul 04, 2011 | Nokia 6300 Cellular Phone
IPhone 4 screen replace
Replacing the screen on an iPhone is a difficult job. The digitizer and LCD are fused together as one unit and must be replaced together. You basically have to disassemble the entire guts of the phone from the back before you can get to the screws holding the display on the front.
Depending on whether you have the GSM (AT&T) model A1332 or the CDMA (Verizon, Sprint) model A1349, the procedures are slightly different. ifixit.com has a very good set of instructions with photos detailing each step for both phones.
CDMA iPhone 4 instructions
iPhone 4 Verizon Display Assembly Replacement
GSM iPhone 4 instructions
iPhone 4 Display Assembly Replacement
The part that gives people the most trouble is getting the two cables fed through the case correctly and connected, so pay extra attention when doing that part. It's very easy to pinch the cables and either break them or end up with them too short to reach the connectors on the motherboard. There's a corner on the flex cable that gets caught when feeding it through the hole, and you have to make sure to move the display side to side to make sure you get past that corner.
May 21, 2011 | Apple Cell Phones
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
How do i get to system programming on my norstar m7310 to get to auto relocate
Enter Administration Mode
  • Using you telephone set push feature * * 266344
  • Display will read Password
  • Using you telephone set enter password: 2 6 6 3 4 4
  • Display will read Configuration
  • Press Show
  • Display will read Trk/Line Data
  • Press Show
  • Display will read Sys speed dial
  • Press Next several times until the display reads Set relocation: Y or N
  • Press Change until the phone displays Y for ON or N for OFF
Jul 02, 2009 | NorStar M7310 Corded Phone
Can't get picture to display on ch 4
there is a switch at the back that you can to channel 4 or 3 good luck
Apr 17, 2007 | Sanyo VWM-950 VHS VCR
Toshiba e-Studio 161 Copier Copier Logo
93 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
