Nokia 5700 Cellular Phone Logo
Posted on Jul 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My nokia 5700 twist doesn't work, when it goes to standby the camera starts itself. the camera icon from media folder is gone and I can't use the key pad to type. need help immediatelly, please.....
Anonymous
Level 3:
Guru:
  • Master 832 Answers
  • Posted on Jul 01, 2009
Anonymous
Master
Level 3:
Guru:
Answers
832
Questions
0
Helped
184620
Points
2366
Hi thanks for using fixya!!
You have to bring your Nokia 5700 to a Nokia Care Center near you to further check the hardware error.
Regards!
tip
Avoid "Camera on Standby" glitch with MicroSD
If the camera function will not save a picture and instead gives you the "Camera on standby" warning, but your phone is otherwise working, and you haven't used up all your memory, the problem might be with the MicroSD card. Many Nokia phones format MicroSD with, I think, FAT16, which limits the number of files that fit in a given folder to 256. You may have just filled up the camera memory folder with 256 files and you need to delete some or create a new folder on the MicroSD and use that as the new camera memory bank. Happened with my Nokia 6126 a few minutes ago and I was PISSED until i realized the quick fix.
1helpful
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
Hello ,i have Nokia 5700, when i twist my camera to camera mode it dont show anything , it dont show anything when i twist it on any way. Plz help. Thanks
Me too got the same problem. it is not a software problem but a hardware problem. you will have to consort an expert for this. they will change a strip on your phone
Oct 09, 2010 • Cell Phones
2answers
When i twist my nokia 5700 the camera does not start
it may be software problem or hardware problem. if it is a software problem, re-installing will fix the problem. if it is a hardware problem, you have to consult your near service provider.
Key pad has damaged .my cell is nokia 5700.pls help how to repair
nothing to worry . just go to a nearby shop & buy a new keypad. it is easy to install . just remove the front case. It is very easy to remove. after removing place the new keypad in place of it.  pls rate me  thank you
Gud evening sir im ravi my mobil model no is nokia 3110 c i have one problam my musiplayer is not opening how will solve that prolam
1.Format your memory card
2.Make shortcut on your mobile so u can access very fast to your media player
2.1. In SETTINGS/DISPLAY/ACTIVE STANDBY/ACTIVE STANDBY MODE (TURN ON)/PERSONALIZE VIEW (MAKE IT THAT SHORTCUT BAR IS THE ONLY ONE THERE)
2.2. In SETTINGS/MY SHORTSUTS/NAVIGATION KEY make it so that standby key is 2nd
2.3. Get back to main screen and press DOWN key, options, select, select media player, and save, in organise shortcuts make it 1st and save your progress
3.Upload up to 5 songs
4. Update your media player, mobile will restart him self! BUT!!!...
5. In order to stop restarting u have 3 sec to start updating music library again
6. If u done all at step 2, u need to press fast one time down, central button, left blue line, down, central, up, and central (Need to be pressed in 3 seconds)
7. If u success in this 6th step u hawe solwed problem!
8. Next step is to upload next 5 songs and repeat steps 4-6
(9.) If you cant press so fast buttons to restart uploading I suggest to create a folder named "Amp3" so he can be first when u access to your memoru card so you could
erase him fast to stop restarting, instead formating whole card (In SETTINGS/MY SHORTSUTS/LEFT SELECTION KEY(Make it Gallery, so you can access fast to memory card to delete folder "Amp3"))
(10.)Buttons to erase "Amp3 folder" - While in main screen press : Left blue line, center, left blue line, down, center, center (Need to be pressed in 3 seconds)
(11.)You hawe stopped restarting and kept pics, and images on memory card
32helpful
14answers
Camera on standby mode nokia 6288
this problem due to track open in the flexi cable(slide strip).please try to change it
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
