Question about Panasonic Televison & Video
After about 1 hour the picture begins to flash and set powers off
After about 1 hour, the picture begins to flash and then the set powers off. After the red light flashes on powering off an amber light flashes intermittently six times. When this happens I am unable to power up using the remote nor the power knob. I have to remove the plug and then on reinserting, I am able to power up the set again. When this happens, the set only works for about 15 minutes then repeats the same power off sequence.
After letting the set rest for a long while the sequence goes back to the 1 hr showing again before powering off as above.
  • 261 Answers
There's a possibility your power supply isn't working properly, if it was your ballast the one causing it to turn off, you would hear a clicking sound, and i doubt it's your lamp since you do get an image, i recommend you go todiscountdashmerchantdotcom so you can get a detailed troubleshoot this way you can make a decision on which part you do need to fix this situation
Posted on Jul 01, 2009
How do I set day and date? All else is set
SETTING THE TIME
Note:
When the signal is being received (as indicated by the atomic indicator signal)
you will not be able to make any setting or adjustments to the clock.
1. To begin setting the clock, press and hold the MODE button located on the back
of the clock for 3 seconds to enter the TIME setting mode.
2. The HOUR digits on the display will begin to flash. Press the UP or DOWN button
to set the HOUR in one hour increments. Press the UP or DOWN button as
necessary until the correct hour is displayed.
Note:
If you are in the 12 hour time format, be sure you are in the correct AM or PM
time period. When the "PM" indicator appears on the display, the time displayed is in
the 12 hour period between 12:00 noon and midnight.
3. Press the MODE button again to exit the HOUR setting and enter the MINUTE
setting mode.
4. The MINUTE digits on the display will begin to flash. Press the UP or DOWN
button to set the MINUTES in one minute increments. Press the UP or DOWN
button as necessary until the correct minute is displayed.
5. Press the MODE button again to exit the MINUTE setting and enter the
SECONDS setting mode.
6. The SECONDS digits on the display will begin to flash. Press the UP or DOWN
button to reset the SECONDS to zero.
7. Press the MODE button again to exit the time setting mode. The clock will
automatically return to the normal time display mode.
Note:
If no settings are made within 30 seconds, the clock will automatically return
to the normal time display mode. If this happens, you will need to start the time
setting procedure again from step
SETTING THE CALENDAR
1. Press the MODE button (located on the back of the clock) twice (do not hold the
mode button) to display the CALENDAR.
Note:
The YEAR icon will be shown on the display indicating you are in the year
display mode.
2. Press and hold the MODE button for 3 seconds to enter the CALENDAR setting
mode.
3. The YEAR digits on the display will begin to flash. Press the UP or DOWN button
to set the YEAR in one year increments. Press the UP or DOWN button as
necessary until the correct year is displayed.
4. Press the MODE button again to exit the YEAR setting and enter the MONTH setting
mode.
5. The MONTH digits on the display will begin to flash. Press the UP or DOWN button
to set the MONTH in one month increments. Press the UP or DOWN button as
necessary until the correct month is displayed
6. Press the MODE button again to exit the MONTH setting and enter the DATE
setting mode.
7. The DATE digits on the display will begin to flash. Intermittently pressing and
releasing the UP or DOWN button to set the DATE in day one increments. Press
the UP or DOWN button as necessary until the correct date is displayed.
Note:
The day of the week will automatically set according to the month, date, and
year.
8. Press the MODE button again to exit the calendar setting mode. The clock will
Note:
If no settings are made within 30 seconds, the clock will automatically return to
the normal time display mode. If this happens, you will need to start the calendar
setting procedure again from step 1
Dec 09, 2014 | Westclox 70026A LCD Atomic Digital Alarm...
How do I set the time on Timex T231 clock radio?
Setting The Time of T231
NOTE: The time can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows 'OFF' and then reverts to the time.
1. If the display is flashing, press the HOUR / REV button to advance the display to the correct hour. If the display is not flashing press and hold the CLOCK button until the display begins to flash, then press the HOUR / REV button to advance the display to the correct hour. Observe the PM indicator to confirm that you have set the hour correctly. If the PM indicator is 'On' the hour on the display is PM. If the PM indicator does not appear the hour on the display is AM.
2. Press the MIN / FF button to advance the display to the correct minute.
3. When the correct time is flashing on the display press the CLOCK / PRESET button once more. The display stops flashing and the clock begins to run.
Oct 01, 2014 | Timex Audio Players & Recorders
How do i set the Barbie Glamtastic alarm clock radio
Barbie Glamtastic Alarm Clock Radio 11765268
There are four (4) buttons on the back:
  • Mode
  • Set
  • Scan
  • Reset
Everything regarding setting dates and times is done starting with the Mode button, and using the Set button to adjust various settings.
Set Year
  1. Press Mode until the date appears.
  2. Press Set. The year will begin to flash.
  3. Press Mode until the correct year is reached.
  4. Press Set.
Set Date
  1. Press Mode until a date appears in the form of MM-DD.
  2. Press Set. The year may flash first. Press Set again. The month (MM format) will begin to flash.
  3. Press Mode until the correct month is reached.
  4. Press Set. The day (DD format) will begin to flash.
  5. Press Mode until the correct day is reached.
  6. Press Set.
Set Time
  1. Press Mode until the time displays.
  2. Press Set. The hour will begin to flash.
  3. Press Mode until the correct hour is reached. Keep in mind the AM/PM indicator in the far left of the screen. Make sure that the hour to be selected is with the correct AM/PM indicator.
  4. Press Set. The minutes will begin to flash.
  5. Press Mode until the correct minute is reached.
  6. Press Set button.
Set Alarm
  1. Press Mode until the the Alarm screen displays. The Alarm screen has an AL in the far right of the screen.
  2. Follow steps 2-6 above under Set Time (these same steps are just being done on the Alarm screen).
Turning Alarm On and Off
The left side of the radio has an On/Off dial (for the radio) at the top, and a slide selector button (for turning the alarm on and off) at the bottom.
  • Sliding the selector to the far left will result in Barbie's voice as the alarm.
  • Sliding the selector to the far right will result in a piercing noise as the alarm.
  • Sliding the selector to the middle slot will result in the muting of the alarm.
There are graphics on the left side of the clock that denote each result above.
Mar 28, 2014 | Barbie Glamtastic Alarm Clock Radio...
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
Lost instructions for TE109 appliance timex timer.\r\nCan you help? Thank You & Merry Christmas
    • Plug your Timex seven day timer into a standard electrical outlet. Allow the timer's rechargeable battery to charge for at least 10 minutes before attempting to program the appliance; the battery will serve as a backup power source to prevent your custom programmed settings from being lost in the event the timer is unplugged or the power goes out.
    • Press the depressed "RST" button on the timer with the tip of a ballpoint pen to reset the timer's internal memory.
  • To Set the time on your Timex timer. Press and hold the "Set" button for three seconds or until the day-of-week indicator begins to flash. Press the "->" or "<-" button repeatedly until the desired day appears on the digital display; press "Set." Use the "->" or "<-" buttons to set the hours when they begin to flash; press "Set" when the desired hour is shown. Use the same process to set the minutes, then press the "Set" button again to confirm the day and time settings.
    • To Program a start time for your seven day timer. Press the ">" button to access the appliance's programming mode; the program number will begin to flash. Use the "->" and "<-" buttons to highlight the desired program number, then press "Set." Highlight the desired day and press "Set" again. Program the hour for your timer; press "Set." Set the minute and press the "Set" button to confirm.
    • wait for the timer to go back to std mode (like 10 seconds)
To program a stop time for your timer. Press the "Set" button to cause the day-of-week indicator to flash. Highlight the desired day and press "Set" to confirm. Adjust the timer's hour with the "->" and <-" buttons; press "Set" when the desired hour is shown. Set the minute for your timer and press the "Set" button again. Press the "Time" button to exit the setting mode.
Dec 17, 2010 | Timex Hardware & Accessories
How do you set the clock on a 2006 royal star tour deluxe?
Select the clock (push the "select" button for at least 2 seconds).
Push both the "select" and "reset" buttons for at least two seconds.
When the "hours" digits begin flashing, push the "reset" button to set hours.
Push the "select" button, and the "minutes" digits will begin flashing; push the "reset" button to set minutes.
Push the "select" button to start the clock.
Mar 03, 2010 | 2006 Yamaha Royal Star Tour Deluxe
Operating Instructions Model No BA218
Setting the time and calendar
1. Press the [TIME] button once to enter Time Mode. The display shows the current time with hour, minutes, and seconds digits.
2. Press and hold the [SET] button for more than one second. The "Hour" digits of the time will begin flashing.
3. While the "Hour" digits are flashing, press the [^] or [down] button to set the desired hour time. Note: Press the [^] or [down] button once to advance the setting forward or backward by one digit. Pressing the [^] or [down] for more than one second will accelerate the forward or backward setting at a higher rate.
4. When the desired hour time is reached, press the [SET] button again. The "Hour" setting will be confirmed and the "Minute" digits will begin flashing.
5. While the "Minute" digits are flashing, press the [^] or [down] button to set the desired minute time.
6. When the desired minute time is reached, press the [SET] button again. The "Minute" setting will be confirmed and the "Year" digits will begin flashing.
7. While the "Year" digits are flashing, press the [^] or [down] button to set the desired year.
8. When the desired year is reached, press the [SET] button again. The "Year" setting will be confirmed and the "Month" digits will begin flashing.
9. While the "Month" digits are flashing, press the [^] or [down] button to set the desired Month.
10. When the desired month is reached, press the [SET] button again. The "Month" setting will be confirmed and the "Date" digits will begin flashing.
11. While the "Date" digits are flashing, press the [^] or [down] button to set the desired Date.
12. When the desired date is reached, press the [SET] button again. The "Date" setting will be confirmed and the calendar setting is complete.
Feb 21, 2009 | Oregon Scientific WW338H Weather Station...
How to adjust time and date
To set the Time:
1. PRESS the [Select] button and hold in for 2 seconds. Located in Field 3, the seconds will begin to flash
(Fig. 11).
2. PRESS the [+] button to scroll the seconds upward or
PRESS the [-] button to reset the seconds to zero.
3. At the seconds desired, PRESS the [Select] button to move to the next setting. Located on right of Field 2,
the minutes will begin to flash.
4. PRESS the [+] button to scroll the minutes upward or
PRESS the [-] button to scroll the minutes downward.
14
5. At the minutes desired, PRESS the [Select] button to move to the next setting. Located in the center of
Field 2, the hour will begin to flash.
6. PRESS the [+] button to scroll the hour upward or
PRESS the [-] button to scroll the hour downward.
7. At the hour desired, PRESS the [Select] button to move to the next setting. Located in Field 1, the 24 or 12
hour clock setting will begin to flash.
8. PRESS either the [+] or the [-] button to toggle between the 24hr and 12hr.
Note: If the 12 hour clock is chosen either AM/PM will appear below the hour in Field 2.
9. At the clock setting desired, PRESS the [Select] button to move to the next setting. Located in the center of
Field 2, the year will begin to flash (Fig. 12).
10. PRESS the [+] button to scroll the year upward or
PRESS the [-] button to scroll the year downward.
11. At the year desired, PRESS the [Select] button to move to the next setting. Located in the center of Field 3,
the month represented by a number will begin to flash.
12. PRESS the [+] button to scroll the month upward or
PRESS the [-] button to scroll the month downward.
13. At the month desired, PRESS the [Select] button to move to the next setting. Located to the right of Field 3,
the date will begin to flash.
14. PRESS the [+] button to scroll the date upward or
PRESS the [-] button to scroll the date downward.
Note: Once the user has determined the year, month and day, the Wristop Computer will supply the day of the
week in Field 1. The American month/day -view can not be changed to a day/month -view.
15. At the desired date, PRESS the [Mode] button to accept the changes and return to the main mode.
Note: If the user does not press any button for 1 minute in the setup mode, the display will automatically exit
setup.
Aug 22, 2008 | Suunto Vector Wristwatch
Advent HT2751A display no good until after 1-2 hour warmup - maybe
After 3 years, I finally decided to open up the TV and do some troubleshooting. Found out the problem, It was a blown capacitor Location C554 Capacitor value is 2200uF 16V - costs about a dollar to replace yourself and the TV works brand new.
Aug 16, 2007 | Recoton Advent Advent HT3251A TV
Televison & Video Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
