Small screws in concrete wall
SOURCE: BOSCH 11236VS HELP ME WITH A PROBLEM
I order parts for my Bosch tools at WWW.toolpartsdirect.com. They have the parts lists also so it is easy to find what you need. Don't forget to order some bosch grease for your tool because you will need to carefully wash-out all the old grease with metal bits. Good luck with you repair. Enjoy
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
SOURCE: bosch 1199vsr stopped working while drilling
your tool should have a rotating reversing switch and the contacts for the forward rotation might be dirty or burnt. I would unplug the tool and remove the screw holding the back handle half on and look to see if anything is burnt or just dirty or bent. If you have an air compressor try blowing thru all areas of the tool. Let me know if this doesn't work you can also go to Boschtools.com and type in your model number on the left hand side after clicking on manuals.
SOURCE: trying to drill a solid concrete 10 inch wall
the ideal sollution is to fully service the machine but there may be a quick fix.
remove the 4 screws that hold the black plastic handle assembly, and take the handle off. on the top of the drill you will see an oil filler cap. unscrew using a 10mm allan key.
empty out any old oil. rinse out with some parafin if you like. empty out again . put some new oil in and replace the cap. 50cc of transmission fluid / power steering oil will do the trick. if this dousnt fix it then you will need to replace the o-rings on the pistons, if this is the case, drop me a email and I will send you a parts diagram. paul@wysehire,gi
good luck.
