Home | Multimedia Projectors | Sharp digital multi med...
Problem for Multimedia Projectors
Generic problem for all Multimedia Projectors
Sharp digital multi media projector PG M10...
By perfect-man on Nov 08, 2007
Screen show keeps cutting out for 5 - 20 secs although the projector is still operating and somes back on again for 5 mins or there abouts. Adrian Allen
Same Problem
Mar 03, 2009
-   NEC np200 projector that flickers the image from PPT. flickering starts about 4th slide into show. I changed display settings to 800x600 and 60 MHZ --- projector continues flickering. What try next? -   mernst6200
Feb 20, 2009
-   Do you mean to unplug the HDMI cable and hook up the older yellow, red and white cables? -   Vaak
Solution #1
posted on Mar 29, 2008
Somewhat Helpful)
dhiman
Rank: Wiz
Rating: 83%, 98 votes
pls tell the problem clearly as this is solveable
Comments:
Apr 15, 2008
- Hello,
Pls change the input type with remote to Yr/Pb to RGB. the signal will work correctly.
Must revert if you still not able to solve the problem.
Viren@ravechd.com
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Multimedia Projectors
Questions and Unsolved Problems for Multimedia Projectors
Answer
High picture quality durability bulb life time and sound quality etc.More conserned.
Answer
Looking for 3-d projector for an art classroom. I need a simple easy to use projector. thanks
Answer
Pluged in a laptop and the projector simply turned off
Answer
Projector comes on. Picture looks good. Is on for approximately 1 minute. Projector lamp goes off.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Multimedia Projectors:
Top Multimedia Projector Experts
Rank: Guru Guru
Solutions: 1178
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Multimedia Projector Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
