Question about Pioneer VSX-D514 Receiver
My receiver shut off after use & will not power on
My receiver shut off after use the other day and I cannot get it to power back on? I let it sit for days to cool off but it will not turn on. Any suggestions?
    President:
  • Pioneer Master
  • 1,114 Answers
Pop the top and check the fuse by the AC plug on the inside. Chances are you will need a meter to do this since most receiver fuses are either white or gray. If you have a multimeter, dial it to ohms and you will see a sign that looks like -))) When you touch the two leads together you should hear a tone and if digital, the display will read "1." Take the leads and touch either side of the fuse, if you hear tone, fuse is good. No tone, bad fuse. Radio Shack carries fuses of all types and usually has them in stock, and can test yours for you as well. If the fuse is O.K. then your unit needs to be serviced. It's either a power supply, transformer, or chipset. Hope this helps
Posted on Jul 01, 2009
My receiver just shut off while watching a movie and won't turn back on. I checked the only fuse i could find. Where to go from here.
Press and hold the "straight" and "Tone control" buttons and press power. This should release the protect lock that the receiver is in. If it shuts back off immediately, then you most likely have a blown amp that will need to be repaired.
Apr 16, 2015 | Yamaha RX-V373 5.1 Channel AV Receiver
My yamaha rxv595a keeps on shutting itself off when im watching movies as soon that it gets loud it shuts off but its not even that loud how do i fix this problem i tried the ohms switch in the back and it...
That is a safety switch in most receivers. When something gets too loud it cannot give the load off to the speakers and shuts off to protect itself. This can mean that the receivers getting old, or that you might need to split the job. You might need an stereo amplifier to split the job. Check the cables and speakers. Recievers can only give so much to so many speakers at so much sound. That is what the whatts are for. The more whatts the better, the lesser whatts, the lesser speakers its going to be able to handle at high volumes.
Feb 28, 2011 | Yamaha RX-V595A Receiver
My Onkyo 808 shuts down when i raise the volume, and when I try to set it up using the micophone.
Amps shut down in most cases because the receiver is detecting and impedance (below 4 ohms) that might damage the amplifier. Do a quick check of the speaker connection and look for wires that might be shorted to the frame or have crossed each other. This is the most common cause of the unit shutting down. Check your speakers impedance if you have a meter. If you don't then unplug power from the unit and then un-hook all speaker wires from the receiver. Next connect just one speaker (Front Left) and power the unit back on and take the volume up. If it shuts down then try the Front right all by itself, bring the volume up again. If the unit seems ok then add one speaker at a time and test. Continue until you find the bad speaker/cable. Your amp should be able to drive speakers down to 4 ohms. The NR808 has power monitoring (sometimes called crowbar) that looks for to much current and then shuts down. I suspect you may have a short in a cable or in a speaker. The 808 is a great amp and hopefully your problem is external. If your amp continues to shut down even with just one speaker connected then one or more of your channel amps (internal) is likley bad causing the unit to shut down. Good Luck.
Dec 09, 2010 | Onkyo TXNR808 Receiver
Yamaha RX-v800 av receiver will not power up. Was playing and just shut off & will not powere up again. Was in a stereo/tv cabinet with closed glass doors. Cabinet compartment has vent holes in back....
Mine did the same thing two days ago. No reason to suspect overheat as mine is in the open. Could be the power supply? Mine comes on after sitting for a while.
Nov 18, 2009 | Yamaha RX-V800 Receiver
HTR-5890 receiver keeps shutting down
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Nov 14, 2009 | Yamaha HTR-5890 Receiver
I turn on my Pioneer VSX-D509S 5.1 surround amp comes on for a few seconds and then it says "powering off"... and shuts off
Disconnect all your speaker wires from the back of the receiver and turn it back on. If it shuts off, you need to have it serviced. If not post a comment and I can walk you thru troubleshooting. Hope this helps
Jun 24, 2009 | Pioneer VSX-D509S Receiver
Denon AVR-1803 keeps shutting down
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Mar 17, 2009 | Denon AVR-1803 Receiver
Amp protection mode
Disconnect everything from the amp except the power cord, then power on the amp. If the receiver still shuts down, your problem is inside the case and unless you can perform electronic repair yourself you will probably need to take it in for service. If it does not shut down with nothing connected, power it off, connect one speaker or component and power on again. Repeat the process until the amp shuts down and you may have found the bad speaker or other component.
Jan 01, 2009 | Onkyo TX-SR503 Receiver
Sound turns on and off intermittantly through unit
You may have a bad protection relay or solder joint at the relay mount position. This relay prevents power supply "thumps" when the unit is first turned on, and also shuts the amp down when there is an overload problem....accordianman
May 29, 2008 | Yamaha RX-V661 Receiver
Receiver shuts down after loud bang
You said Unit is enclosed!! Does that mean it is inside something? Receivers & Amps need to have a clearance above them so air can circulate, otherwise you'll have an overheating problem. You also might have some of your wires crossed which will cause the Amp to shut down. Look at all your connections and make sure they're correct, including speaker wires.
Sep 22, 2007 | Audio Players & Recorders
Pioneer VSX-D514 Receiver Logo
455 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
