Gateway laptop no power. Working ok last night checked power supply pack all ok 19v coming through But wont power laptop help
  • 85 Answers
Remove the battery and try to power it. if this fail, them change the memory and then the processor if this also fail then one of the power chips on board is bad (also check the power connector if is not soldered properly.
Posted on Jul 01, 2009
Laptop wont come on
Look at the label on the back of the charger for this Gateway 3701. You should see something like this:
  • Input: 100-240V, 50/60Hz
  • Output: 19V 3.42A
If the one you have is not the correct one, you can buy one online (E Bay) for less than $15.
Nov 09, 2013 | Gateway Computers & Internet
My Gateway M-6750 laptop was working last night but today when I tried to turn it on the power button light flashes on and off and nothing else. I have unplugged it and removed the battery and held down...
Remove the main battery and the power supply charger, allow a few minutes to get rid of any residual charge. Replace the battery, press power, if there is no change, remove the battery. Now plug the power supply back into the laptop, press the power, if it starts up the battery is bad and needs to be replaced.
Jan 13, 2011 | Gateway M-6750 Notebook
My Gateway laptop use AC cord with the output 19v = 3.42A. can I use the AC cord with the output 19v = 3.95A?
Yes you can use one that has an higher current rating. The system will only use what it needs. If you try to use one with an lower current rating the power supply would fail. Just check to make sure the pin out is the same..ie postive tip or negtive tip.
Feb 23, 2010 | Gateway HQRP Replacement Laptop AC Adapter...
Charger light flashes when plugged into laptop , stays on solid when unplugged,had charger checked 19v ok ,had socket checked 19v ok ,then checked to first board 19v ok ?? has a board gone down ??? annoyin...
your battery pack is causing your problem rule #1 never!! leave the charger in!! everytime you start up!! run off the batteries till the power low light come's on then apply the charger constant charging causes early failure of all/ any nican battery pack
Jan 13, 2010 | Acer Aspire 5920-6335 Laptop
The ac adapter is not working for my gateway laptop any ideas?
is the green/red light lit? If you have a multimeter check the plug end to see if there is voltage flowing.
Other than that you can purchase a new power pack online through ebay or the Gateway site online.
cost about $45-50
Ple4ase rate my help++++Thanks for using fixya
Nov 17, 2009 | Gateway (1532852) Power Supply
Gateway desktop won't start up
Here are a couple of links that may help you to diagnose the problem...it could be your power supply is partially failing, but that's just a stab in the dark.
See here and here and here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 04, 2009 | Gateway GT5654 Desktop PC
My toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Mar 19, 2009 | Toshiba Satellite 2455-S305 Notebook
No Power
Same here - mine has died in the last hour . . all of a sudden the battery light comes on 'as if to charge' - then goes out.
any help would be appreciated..
Aug 02, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Laptop will not power on at all.
Don't know what you have for a laptop, so will have to give you a generic process, here. Power down. Remove hard drive, remove cd reader and/or floppy drive. Remove memory cards. Replace only 1 memory card in the main slot (probably marked as slot 1). Try to power it back up and let us know what happens.
Thanks!
Ron-
Nov 02, 2007 | Computers & Internet
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
