Question about Sharp Computers & Internet
Hi, can you help me with a problem I am having with my Sharp LL-T17A4-H Monitor please? Sometimes the screen displays properly, but a lot of the time recently it just shows a few lines with a purple-ish background over part of the screen. When once it was like this, and for no reason,the desktop began to appear from the top of the screen and, by notches, went back to a normal desktop for a while. Your thoughts please.
  • 1 more comment
  • davdaron Jul 01, 2009
    Hi, thank you for your advice. Have already tried your suggestions without success and really have reached the same conclusion as yourself and that is to go for a new monitor.
    thank you once again
    Thank you.
    Hi, thank you for your continued advice. Being disabled, I was hoping to get the monitor up and running more as a project and with that being the case, I have checked inside the monitor and noted that there are 2 boards inside, both are located by screws. So no soldering would be required to replace the offending board. If I was able to determine which board is at fault, thought I may be able to find another board from somewere and replace the faulty board. Have you any way of advising me which board I would need to purchase ( gived the price etc.)?
  • 1,056 Answers
Try this first. Click Start Menu - click Control Panel - click devices - click the + sign on devices click the name of your graphics card check the status box to see if it is working or needs replacing.
Next is Click start menu - click control panel - click personalization - click Dispaly setting - slide the resolution bar to a different setting. If these don't work. Try connecting another monitor to that same computer or connect that monitor to another computer. If all these failed, do not take the monitor to a technician, to get it repaired. It would generally cost more to fex them than buying a new one. The replacement boards on these monitors are priced almost the same as the monitor itself, plus the technician fee. The boards in these monitors can't be fixed by a regular electronic repair shop. The surface mount technology used in the circuit with complex digital chips are beyond the scope of these shops. Trust me I am an electronic technician for so many years. Good luck
Posted on Jul 01, 2009
  • 1 more comment
  • Ronado Panaligan
    Ronado Panaligan Jul 01, 2009
    I also forgot to add. You can also try to see if there is a loose connection on the wires. make sure the wires between the computer, and the monitor are not loose, since most of the time, Intermittent problem are caused by loose connection.
  • Ronado Panaligan
    One last resort, check also if there is anything that can cause some sort of interferance. Don't rush into buying a new one yet. Note anything being turned on when the problem arise. Use it for a while sometimes, electronic device have an uncany way of operating normally again without the problem ever coming back. I have experienced this on a few occasions. If the intermittent problem occurs more frequently as time goes by, then that is a a component inside on its way to the graveyard. Well that is all I can really think of.
  • Ronado Panaligan
    I have worked on an HDTV flat screen which somehow works the same way as a flat screen computer monitor. I can honestly tell you that it is very difficult to diagnose. The only thing I can really diagnose in it is the power supply system. These monitors are at the top of our current technology, they very complex and just beyond our scope each chip consisiting of hundreds of thousand of transistor to a few million. I have exhausted all my limitations on this.
The stand, attached at the back of the screen, has snapped and needs replacing. Can it be replaced and where can I get one. the screen is fine.
Try contacting Sharp. Places that sell them may have one laying around but I doubt it.
If you can't get one, check the middle of back of the monitor for 4 screw holes (empty) in the shape of a square, they're for attaching to a wall or desk mount.
An example of a desk mount:
http://www.google.co.uk/products/catalog?q=monitor+mount&cid=392981540399473061&ei=3uNbTciZNJe5-QaMn62VCQ&sa=title&ved=0CDQQ8wIwCTgA#p
Feb 16, 2011 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sharp lcd monitor . i am using past one year but now not working only blue screen and two line is come why please help me
Please make sure that the cables are all securely plugged into the back of the monitor, and into the back of the computer. Also make sure that there is nothing that was recently placed near your monitor (or your monitor's cables) that can cause interference.
If this does not fix your problem, try connecting your monitor onto another computer to see if it works there. If it still does not work, even when connected to another computer, it is possible that your monitor cable is faulty, or the monitor itself is faulty. I recommend taking your monitor and it's cables to a computer repair shop for further repairs.
If it works on another computer, but not yours, then it is possible that your graphics card or computer may be the cause of the problem. Open the side panel of the computer and make sure your graphics card is securely plugged into it's slot. If this does not fix the problem, I recommend taking your computer in to a computer repair shop for further repairs.
Dec 18, 2010 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sometimes the screen goes blank and today when I restarted the computer the screen is flickering very lightly.Does this means its going?
The picture board on your monitor is bad, since the power led or button is on and all connection are corrrect, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jun 30, 2010 | Sharp LL T17A4-B 17" Flat Panel LCD...
I need to find drivers for a Sharp LL T17A4-B 17 in. Flat Panel LCD Monitor. I recently changed it to a different tower and cannot find the driver for it.
Hi
Thanks for using FixYa. You can download its drivers by clicking on any of these two links:
Sharp LL T17A4-B Drivers
Sharp LL T17A4-B Drivers-2
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 08, 2010 | Sharp LL T17A4-B 17" Flat Panel LCD...
Lcd monitor will not stay on
First thing to try, is to check the cable from Monitor To PC Or Graphics Card.
If you have a loose-broken internal wire, this will be the problem. Dry-Solder Joint et,c.
If the cable, has a socket either end, from monitor to computer.
try to obtain a replacement cable. The second option is to test the output source. i.e Graphics card or output to the monitor.
Hope this helps Mike @ Compurepair.
Sep 16, 2008 | Sharp LL173C 17" Flat Panel LCD Monitor
Sharp ll-t17a4-b backlight
when ever i try to sign in the messanger says erorr code 80072efd how can i solve this matter
thanks
jem
Oct 21, 2007 | Sharp LL T17A4-B 17" Flat Panel LCD...
Problem with the monitor
Have you tried another monitor on the PC? If the cable and connector pins are okay, I would suspect a problemn with the video / signal board inside the monitor.
Jan 21, 2007 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sharp LL T17A4-B (Black) 17 in.
Are you using the digital connection?? If so try using both the analog and digital connection then set the digital as the Main monitor in your graphics card interface. To check if the backlight is out, darken the room, and light a flash light into the screen. If you can see a picture, then you need to replace the backlight. Good luck
May 03, 2006 | Sharp LL T17A4-B 17" Flat Panel LCD...
Computers & Internet Logo
Top Sharp Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
