Question about Car Audio & Video
Changed the battery yesturday in my Mazda rx-8. Now my radio/CD and my A/C won't work! It's all black! Wot to do???
    President:
  • 1,114 Answers
Check the fuses in the fusebox. If you have the owners manual, it will show you where it's located (sometimes more than one fusebox) and where the specific fuses are. Hope this helps
Posted on Jul 01, 2009
2005 Mazda RX 8 won't restart.
could be fuel pump or engine jumped time due to worn timing belt.could have faulty PCM or crankshaft position sensor bes have vechicle code scan before buying new parts.
Jun 01, 2013 | Cars & Trucks
My 2004 RX8 ignition light is on indicating a possible electronics problem. The door lock, the interior and trunk lights are not working. . the radio/CD player does not work and the radio panel,
That's a lot of things out! I think you need to check to see if there is a large fuse blown (Maxifuse) in the underhood panel,or maybe you accidentally unplugged something by accident while charging the battery.
Oct 14, 2012 | 2004 Mazda RX-8
2005 mazda rx-8 won't start
you may need a new ignition barrel
Aug 07, 2012 | 2004 Mazda RX-8
Mazda rx-8
needs new red top battery and a new nz1 starter motor
Jun 26, 2012 | 2004 Mazda RX-8
I have a 2004 mazda rx 8 we may disconnect the battery to clear the "check engine light" -- if we do, will we need a "code" for the radio, or anything else?
You WILL probably need a code. Your car might not remember it as it needs the battery to keep memory. The best way to clear the check engine light is to buy a code reader. Costco has a cheepie one that works great. $35.00 . The code reader will also give you "code" that your car is throwing. Disconnecting the battery to clear the code is only a band-aid fix. If there is a problem with your car the "check engine light" will turn right back on. Just clearing the code obviously doesn't fix your problem.
Sep 26, 2011 | 2004 Mazda RX-8
How to remove the battery from a 2004 mazda RX8
get one of those 9v cig lighter socket power supplies,that will keep codes in yr radio and computer,then you can disconnect the earth first,then positive,then the clamp,then the battery.dont spill the battery acid
Jul 04, 2010 | 2004 Mazda RX-8
I have a 2004 mazda rx 8. I went out to crank it
I have a 2005 mazda rx 8. I went out to crank it up yesterday day and it would not fire. I had started up on Saturday just fine. What could be the problem?
Nov 16, 2009 | 2005 Mazda RX-8
Front speakers not working 2004 mazda rx8
your speaker is burnt out , see an auto electritian cos your car has just short cucuited and is very danderous the whole car could catch fire,
Feb 14, 2009 | 2004 Mazda RX-8
Center Console Display Not Working
Jan 28, 2009 | 2004 Mazda RX-8
Will not start after changing battery changed battery on my 2005 rx 8 mazda last night and it started up fine. this morning just kept turning over and would not start.
If the engine is cranking, it can only be 2 things left, got gas? Are you getting a spark at the plug wire? Check the oil. Some cars won't turn on the fuel pump with no oil, could be the pump. Could be the coils. You have to check these things out and find out which way to go next.
Dec 10, 2008 | 2005 Mazda RX-8
Car Audio & Video Logo
75 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
