SOURCE: we have a spa quip 2.5 maxi flow spa pump,tried to
Hopefully you have not fried the motor. To free a stuck motor: try to reach past the strainer to the impeller and turn it. If you can't do that, remove the electric end cover and find a double flat for a wrench where the shaft goes into the motor. Or maybe you can remove the spring thing from the end of the motor and move the shaft with a pair of vise grips or pliers. Don't damage the place where the spring thing mounts. Don't try to move the motor with the plastic fan thing near the pump, you'll just break it, and then you really have problems.
To keep a motor from sticking, thru off season occasionaly spin the pump, just a few seconds will do, don't need water.
SOURCE: 2 yr old inground pool Hayward pump louder than
If there is air in the pump it cavitates and can make it run louder, otherwise it is the bearings in the motor.
SOURCE: how do i drain the spa i have a sx series hurlcon pump. help!!
you need to be able to divert the suction from you spa pump to the lowest inlet in the bottom of your spa.you might need to install a valve.. jay the pool pump motor repair guy longwood florida
