Question about Brother HL 1450 Laser Printer
Clear memory brother hl 1450
Helloh ow to clear inside printer brother HL-1450 memory ?
  • 4 Answers
SOURCE: Lost Installation CD for my Brother HL-2040 printer
Go tor HP printer drivers on the net.
Posted on Sep 27, 2008
SOURCE: BROTHER Hl 2040 PRINTER WON'T PRING
I got exactly the same problem and the "reset" didn't do anything. I fixed it by putting a piece of duck tape on magic eye on the cartridge.
Fallow those step to do the same thing as me:
  1. Open the front panel.
  2. Remove the toner and the drum
  3. Remove the toner FROM the drum
  4. On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them. I put mine on the right side.
  5. Put everything back in.
  6. Turn on your printer if it's not already.
  7. Now, the low toner light should be gone and the green light should be on.
Now, you can really empty your cartridge.
Posted on Nov 06, 2008
  • 13433 Answers
SOURCE: where can I get brother hl-2030 LASER PRINTER DRIVER
Hey,
The brother drivers and software require for the machine is available at
http://www.brother.com/E-ftp/info/index.html
Let me know if you need anything else.
Thanks,
Ekse
Posted on Mar 05, 2009
  • 10 Answers
SOURCE: How do I replace the drum on a Brother hl 2040.
I have 'reused' the same drum three times and still prints like a charm.
Open the toner door and pull out the toner/drum assembly. Take the toner off the drum tray. Use a alcohol pad or lint free cloth and wipe the mauve coloured drum to remove the excess lint and toner collected on the drum. Rotate the drum with the white gear and keep cleaning until the whole drum is done.
Put the toner back in the drum tray. Clean the corona wire by sliding the blue tab back and forth 3 or 4 times. Put the toner/drum back into the printer and close the door.
After the printer does the self test the drum light will cone on again so then you need to reset the counters.
Open the door again
Hold the GO button until all 4 lights are lit up
Release the GO button
Close the door
Printer will self test and should extinguish all the trouble lights.
Posted on Apr 20, 2009
male_28_cam
  • 1555 Answers
SOURCE: Brother HL 5150D printer has all lights flashing
switch off your printer. Remove power cable from printer. Open upper cover remove cartridge and then re-install. Wait for 5 minutes. Connect power cable again and restart your printer. It will work fine.
Posted on Jun 20, 2009
Where is the cartridge on a brother laser printer HL-1400
I don't see a Brother HL-1400 on their site. However, there is an HL-1440 which uses the TN-430 (regular) or TN-460 (high yield) toner cartridges. This printer also takes the DR-400 drum unit.
This toner cartridge works with several models in the HL-1400 series, including the HL-1435, HL-1440, HL-1450 and HL-1470N.
I hope this helps.
Aug 25, 2016 | Brother HL Office Equipment & Supplies
How do I clear the memory from my Brother HL-1440 printer?
Printer memory will clear if you simply unplug it from the wall. More likely, the old document was in your computer's disk, and you can control what prints from there.
Sep 11, 2014 | Brother HL-1440 Laser Printer
Brothers hl 1450.. quit printing in middle of job, paper jam. All lights on, will not resume printing. I have turned on and off, reset computer.. won't budge.
if all of the lights on the printer are flashing it means there is a physical problem with one of the main parts of the machine( power supply, main board, ect.) try unplugging the machine for a few minutes and plugging it back in, if the problem persists you would need to have it checked by a technician
Dec 02, 2009 | Brother HL 1450 Laser Printer
I cann't install Brother HL-1450, because of a message: C:Windowsinfprnbr001. inf is missing
just uninstall the driver if you already installed. Don’t connect the printer usb cable
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Nov 17, 2009 | Brother HL 1450 Laser Printer
When I print with my bother 1450 hl laser printer, the printer ma
Hello sir; Before we go further I suggest you replace a new cartridge see what happen.
May 18, 2009 | Brother HL 1450 Laser Printer
Brother hl 1440 laser printer, print job stuck in que.
Try to stop the print spool and restart it. This should clear any jobs that's in your pc. As for the printer ususally if you shut it down for about 30 sec, it should clear the printer memory.
hope this helps.
Mar 27, 2009 | Brother HL 1440 Laser Printer
Brother network printer shows tcp/ip disabled
Download the software/driver package from Brother and do a clean install. You have to set it up first (best to do using LAN/wired connection initially).
Aug 23, 2008 | Brother HL 1450 Laser Printer
Brother HL 1450 Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
