Question about Sharp AR 163 Copier
Sharp AR 163 display L6 error
We have two Sharp AR 163 Photocopiers and they were purchased at the same time. Now they both dislay the L6 problem just within hours from each other.
I had tried resetting all the counters but i vein. I had tried a polygon motor test but the motor does not turn.
Please advice what can be done.
  • 313 Answers
The error is for the polygon motor if you have done the test for the motor and it doesnt work I think thereis the answer because they spin so fast the motors will eventually go if it had been a little noisy p[rior to this then it has a read or seize error if you know how to take it out youcan manually gently spin it to see if it is stuck just make sure you use a clean dry cloth to cover it prior to turn as you might mark the mirrors.. Good Luck A
Posted on Jul 01, 2009
  • 22 Answers
Bpbit,
M2tech1 is right, that he suspected that the problem was the polygon motor. Actually its L6 sub 10. That means the polygon motor stops rotating or defective.
The solution for that is to replace the polygon motor.
Posted on Jul 31, 2009
ERROR CODE L6 - HELP PLEASE, THAN KS
L6 in Sharp copiers stands for main drive problem. In this case scenario it is probably the main motor or a link to it like the drive brd.
Feb 23, 2011 | Sharp AR 163 Copier
Sharp AR-163 Copier, How to Reset/Solve the error Code U2-40
how to clear red sing on tonal problem for sharp ar 163
Sep 16, 2010 | Sharp AR 163 Copier
Sharpe ar-163 with error code u-240
Hello sir; The error code you display is CRUM communication error.
Feb 05, 2010 | Sharp AR 163 Copier
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER.
L6 is a problem in the laser sistem. The polygon motor doesn't work. It is reparable if you can get it out of the machine to open it and lubricate it. If it doesn't get ok it can be changed, just the motor and the small printing board. GOOD LUCK.
Nov 25, 2008 | Sharp Office Equipment & Supplies
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER. WHAT IS CAUSING THIS ERROR AND CAN IT BE REPAIRED IN-HOUSE?
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Showing L6
dear friend:-you can check what is wrong in the movement of optical system .is there any foreign object stuck the movement-is lenses and optical system cover installed in a right way-try to remove the cover and reinstallit.-check lens home position detector connector.
Feb 23, 2008 | Sharp AR 163 Copier
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
1,143 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
