Question about Lenovo IBM ThinkPad T43 Notebook PC - Intel Pentium M 1.86GHz, 512MB DDR2, 40GB HDD, Combo, WiF
The little switch that let the screen light back up when thinkpad is opened is not working can wiggle it some times and get screen to come back but getting worse. I can hook up a seperate monitor and thinkpad works fine. just cant get screen to come up cause i think the spring in there is messed up. thanks Ruth
  • Lenovo Master
  • 19,396 Answers
The switch is part of the upper casing to replace it you mest replace the upper casing of the Thinkpad.
Try first blowing some canned air to remove dust and playing with the little lever to unlock it.
Posted on Jul 01, 2009
My hp zx5000 back light does not light
Real easy solution please note when your laptop is open there is a little white plastic stem type switch (micro-switch). This switch controls the back light, when the computer screen is lifted into the operation view (user view) the switch provides power to the screen.
Easy fix as long as the back light works just SOFTLY push the white stem down several times. This should clean off the dust which probably got under the micro-switch.
If this doesn't work then your back light needs to be replaced!
Aug 13, 2011 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Info req'd on user part of linova r61e thinkpad
Some Lenovo and ThinkPad computers have a LED light that is located on the top edge of the screen and can shine a light on the keyboard.
To switch on this LED light, press the Fn key plus the PgUp key (This key maybe different on some model laptops).
Feb 21, 2010 | Lenovo ThinkPad R61e Notebook
Won't turn on unless wiggle cord
Had the same problem and cord wiggling worked for a while then no lights anyway I tried. I opened up the handle, and the 3 screws below the handle, to disassemble that part and looked into the little circuit board. The little on/off switch worked directly from the cb so just re-seated everything and Wiola! it works now. Seems like the little silver on/off button at the top loses contact with the actual switch inside and in my case re-seating restored that contact.
Hope this helps..
Feb 11, 2010 | DeLonghi WR25 Retro Belgian Waffle Maker
The red laser pointer underneath the mouse isn't coming on? put new batteries in and the receiver is showing the green light once plugged into my laptop.
I doubt the problem is the battery. I have this same mouse and it has worked beautifully for two years now EXCEPT for one problem: most of the time, the mouse does not turn on when the receiver is removed from the receptacle on the bottom of the mouse. There is a tiny little switch built into that receptacle, along the side wall of the receptacle not far from the light. I have to wiggle this little switch (gently!) by hand a few times until the light comes on. From that point, the mouse will work fine until the receiver is placed back in the receptacle.
Dec 07, 2009 | Microsoft Wireless Notebook Optical Mouse...
How do you put on the little ligh that is on top of the screen
on your keyboard, pressing FN + PgUp (both key at the same time) will turn it on for you.
Nov 23, 2008 | IBM ThinkPad X41 Tablet PC
IBM Thinkpad T20
try to check your settings on the display properties ->screen saver->monitor power. make sure the power is turn off never.
Jun 30, 2008 | IBM ThinkPad T20 2647 Notebook
LCD
First try this, right click on the desktop, click properties, open the screen saver tab, click the power button, then change the screen settings to never. If this doesn't work, then I'm afraid it's a hardware issue. Check the screen connections, connection to the back of the screen, screen to inverter, and screen to motherboard (under the keyboard), sometimes the connectors can work loose. If the connections are good, then the issue may lie with the inverter or screen itself. More than likely an intermittent problem with the inverter.
Jun 25, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T42 notebook
Does it happen at a consistant time? Then check the power settings for the computer (screen saver and time to blank the screen.
Also, usually have a little latch of some kind that operate a tiny switch that turns off the backlight when you close the cover. Perhaps this switch is stuck on yours and the laptop may think you have close it. To find it, you must look for either a little spring loaded plunger on the keyboard side, or an opening on the keyboard side that something on the cover inserts into. All laptops have it, but they are all different. When you find it, push on it to verify it works.
Apr 23, 2008 | IBM ThinkPad T42p Notebook
Laptop screen
Sounds like the switch that tells the cpu when it's open or closed is going bad. On most laptops there is a little switch that protrudes from your keyboard (usually in upper corners). Try cleaning it with isopropyl alchol(rubbing alchol) and a q-tip and see what happens. If you can't locate the switch on your model get back to me and i'll research a little deeper for you. Hope this helps
Sep 14, 2007 | IBM ThinkPad 770 Notebook
Lenovo IBM ThinkPad T43 Notebook PC  - Intel Pentium M 1.86GHz, 512MB DDR2, 40GB HDD, Combo, WiF  Logo
64 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
