Question about NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g
Trying to install wireless router but my laptop doesnt have a disk drive to install disk. is there any way of installing over the net
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 01, 2009
INSTALL MICRONEXT WIRELESS USB ADAPTER WITHOUT DISK
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver if you see a yellow ? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
the driver could be on the motherboard disk or the one supplied by your ISP internet service supplier or you might need to download it
http://download.cnet.com/realtek-rtl8187b-wireless-802/3000-2112_4-206215.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109025.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-pro-100-m/3000-2112_4-109029.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109002.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109004.html
hope one of these will help
Feb 25, 2012 | Computers & Internet
Im trying to hook my desktop up to the wireless router so that me and my dad (both with laptops) will hook up wirelessly. I tried reseting Linksys Broadband Wireless G Router and made sure all of the...
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
Dec 31, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
I changed my drive C to XP I had to format the disk and lost the software for the wireless lan driver,The application& support disk does not download it either for XP or for the Partition drive D which...
Use an Ethernet cable to connect from the network-port on your computer to one of the LAN ports on your router, to get Internet access.
Then, access http://WindowsUpdate.Microsoft.com
and click "Custom" scan.
When it completes, on the left, click "Optional Hardware",
and see if Windows Update is offering you a device-driver for your wireless adapter.
If so, check-box that driver, and install the update.
Sep 28, 2010 | Medion MD-40954 Notebook
Reinstalled vista home basic on acer aspire 5520 wireless
Do you have a disk or the wireless router? If this hasn't been re-installed then the notebook will have no way of connecting to the net.
Oct 06, 2009 | Acer Aspire 5520-5908 Notebook
The cd install disk says it doesnt support the op system
I suggust you goto the netgear website and download the software from there, of course you will need access to the web
Oct 01, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
My laptop computer says the adpter is not detected we have ran th
You can connect the Cat 5 cable from your laptop to one of the ethernet ports from router to download. Or download from any computer to a  Jump drive then install to your lap top.
Sep 08, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Laptop no cd rom no flash drive need installation file please
It will be quicker for you to go online at www.linksys.com and download.
Let me know if you need anything else, or any help setting it up.
Feb 04, 2009 | Linksys Wireless-G Broadband Router
Belkin router
as long as you know your isp password and usename for your broadband connection, all you need to do is connect to the router via an ethernet cable and type in your web browser 192.168.2.1 to enter.
You will need to the router login details which is normal 'admin'
select ppoa or ppoe depending on your isp and the router should connect to the net
Sep 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g Logo
78 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
