Question about Kenmore Washing Machines
What is the proper way to transport a used stacked washer/dryer in my trailer?
  • 158 Answers
It is best to transport it upright and tied down with rachet straps. Make sure you have it strapped down tight and side to side and front to back. If you cannot move it this way, it will not hurt the unit to set it down on it's side. as long as it is not full of water. As long as it is dry it is safer to gentlty place it on its side. Always use tigh down straps. Be careful
Posted on Jul 01, 2009
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool dryer model # WED9270XW1? If yes, what stacking kit do I need to use?
You can stack just about any dryer on any washer, so long that the controls of the washer are on the the top of the washer has no penetrations and no control.In general, dryers are independent from the washer and are light weight.
So the conclusion: so long that the dryer does not interfere with operating the washer - YOU ARE A OK :-)
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool washer model # WED9270XW1? If yes, what stacking kit do I need to use? Can I stack a new whirlpool washer model # WFW72HED
As we could see new one are not compatible with older one as size and dimension of new washer are changed but in case you could try .It is simple just try compatibility of your older washer stack kit with new one in most new model
Stacking washer and dryer still vibrating and walking during spin cycle even though stacking kit is attached
Assuming that you've installed the stack kit according to instructions, you should check the following:
1. The dryer should be securely attached to the washer and not wiggle or move. The washer must always go on the bottom of the stack.
2. Washer should be level and have all four level legs making solid contact with the floor, no wobbling.
3. Make sure the drain hose is not pinched or restricted (or there is not debris in the drain pump) as a slow pump out will accentuate vibration problems.
4. Make certain you've removed all of the washer packing bolts before using the machine (see owners manual for description.)
5. The floor must be solid with no "springy" or "spongy" feel. No matter what you do to the laundry set it will vibrate on a less than solid floor. This occurs on upstairs installations or other wooden floors, especially in an older home. Sometime the floor can be braced to stiffen it. Also, vibration pads are sold that might help minimize the vibration. The walking is a symptom of vibration.
Experience shows that most problems of this sort result from incorrect installation and/or flooring issues, not the laundry. You should not attach it to the wall. It is possible the washer has a problem in which case a technician would need to check the unit. They can check the suspension and drive system for proper operation.
Aug 24, 2014 | Samsung Front-Load Washer and Dryer stack...
I have a Frigidaire GLET1031 Top Load Stacked Washer / Dryer. The water valves do not work unless the dryer is turned on. Also the washer drum will not spin with dryer on or off and the dryer does not get...
WHat ya need to check is for proper power going to the entire unit it sounds as if either a breaker is off or their is burnt/broken wire from the main power connection.
All symptons listed i suppose occured suddendly?? and to me its a lack of proper electrical power that is causing all of them.
GENE
Oct 03, 2011 | Frigidaire GLET1031 Top Load Stacked...
1989 (?) GE Spacemaker washer in a park model trailer has a cracked plastic air pressure tank. No model # on washer, how do i get parts.
You do need the model number to order parts...typically on a stacked unit the model number is inside the dryer door
Sep 08, 2011 | GE Spacemaker Washer and Dryer Electric...
Can the Whirlpool Duets stack?
The simple, short answer is yes, the Whirlpool Duet washer and dryers can be stacked. You'll need to check with the Whirlpool folks to see if you'll need a stacking kit, or if they are ready to go with what you already have.
The key to stacking these Duet laundry pairs, is to have both the washer and dryer model numbers when you contact Whirlpool, so they can provide you with the stacking kit needed to mount the dryer on top of the washer. You can also check the Whirlpool web site to get a good idea of how much space is needed for a stacked set. Here's the link for the space checker, just look under the Guides and Tools on the left side and click on the Laundry Space Sizer to see what's needed.
http://www.whirlpool.com/catalog/category.jsp?cat=115
You can also call Whirlpool at (866) 698-2538 and speak to them about your particular washer and dryer.
Hope you find this Very Helpful and best regards!
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Can you move a stackable washer and dryer with it laying down.
It should be fine. Just make sure that any water that comes out doesn't get in the electrical parts of the units. Good luck. Any questions feel free to ask. Please rate me so I know if I helped you. Thanks.
Dec 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Oil leak
A small amount is not serious. There is no good way of adding oil to the transmission unless you want to take the top off the transmission.
Jan 21, 2007 | Whirlpool LTG5243D Top Load Stacked Washer...
Washing Machines Logo
294 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
