Question about Samsung SCX-4100 All-In-One Laser Printer
PAPER JAM 2,CHECK INSIDE(SCX-4521F)
NO PAPER WERE FOUND IN THE BACK AND FRONT PART.BUT I FOUND A BLACK PLASTIC PIECE SEEMS LOOSENED AND JUST HANGING AROUND. I DONT KNOW WHAT SHOULD I PUT IT. CAN ANYONE HELP ME?
    Champion:
  • 220 Answers
Paper jam 2 is your fuser sensor error,need fuser replaced.
Posted on Jul 02, 2009
Samsung scx-4521f "paer jam 2"_ i've checked paper inside but i can't see any thing is jammed. if i turn off and on that time 1 paper will be printer ofter one same problem is repete. any advice sir
Sanjay,
I think you should take all unused papers out, close tray and predd print button. If there is paper in the system, it may come out. A red light may also flash asking you to load papers. Now lod the papers and the red light will go off. Put a printed paper and try copying. If it copies, you are ok. Now print from your cpmputer command. If it prints you are ok. If it does not and you get paper jam warning, there may be a small piece of paper stuck in the system. You have to open each feeder and see if you find anything. Good luck.
Jun 02, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam 2, check inside
You should troubleshoot jamming error message by removing toner cartrige, check if the little plastic sensors on the paper path are not stuck somehow, reinsert toner,close door, open back door check if the fuser sensor is ok ( and not broken), clean the papertray roller, restart printer and it should work. If that doesnt fix your problem it can be a faulty sensor or some tiny paper left somewhere you can't see and sensor detects .. Hope it helps.
Apr 07, 2014 | Samsung SCX 4521F All-In-One Laser Printer
"paper jam 2" after each page with samsung scx-4521F printer
sir, our printer is 4521f model its showing paper jam 2 How to solve this peoblem
Jun 02, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam-2
samsung scx-4521f paperjam2 check inside
Mar 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam #2
If you moved the heating part ... there is an optical contact in tha back of the printer: a mate plastic into an optical contact, The black plastick should stay between the optocal parts.
Apr 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
I had this problem too. For me the answer turned out to be the paper sensor in the back part of the machine, behind the little back door just under the top part of the machine. This sensor hangs down from a thin rod that runs across the width of the machine, and is held in place by a small spring that encircles the same rod that supports the finger. The finger had apparently gotten moved so the spring was dislodged from its proper place. I was able to rotate it around the rod with my finger & get the spring moved back to where it should be. This seems to have cleared the problem--I'm keeping my fingers crossed.
Jan 22, 2008 | Samsung SCX 4521F All-In-One Laser Printer
PRINTER SAYS PAPER JAM 23 ..
thanks J
Jan 11, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
1,022 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
