Question about StarTech.com StarView SV211K 2-port KVM Switch
Eurovox ex1000sl com port
Trying to flash plugged in Null modem serial cable flashed numerous boxes before but on this ex1000sl no com port i have been in device manager and all ports are ok ?
Go to devic then change it to com port 3e manager, select comport 1 then advanced,
Posted on Dec 01, 2009
  • scot32 Dec 01, 2009
    Go to control panel, then system, then device manager, then com 1 and go into advanced options, change the com port 1 to com port 3 on windows xp.
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
http://www.startech.com/au/Cards-Adapters/Serial-Cards-Adapters/USB-to-Null-Modem-RS232-DB9-Serial-Adapter-Cable-DCE-FTDI~ICUSB232FTN
https://en.wikipedia.org/wiki/Null_modem
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
My computer that has PSW2.0 crashed. It had Windows XP. I have a new HP computer with Windows 7. What do I have to do to make it work on my new computer?
From Singerco.com FAQs: Q. My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a? A. We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below:
CUSB-232A available from Computerplug.com and Cablesalesusa.com.
Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
Sep 23, 2010 | Singer Professional Sew Ware Options 2.0...
Eurovox codes!
download the Bigmaq toolbar,all updates and fixes are on there,you need a null modem cable available from ebay or your local maplins etc to connect the box to your computer.flashing takes a couple of minutes,read the eurovox section on Techwatch.co.uk for guides and help.Regards stu.
Sep 09, 2009 | StarTech.com StarView SV211K 2-port KVM...
Zebra 105SE 25 pin serial cable
error can be on the pc.side or the printer's:
check
- if in windows the LPT ports are addressed properly (if u got a many usb ports, then windows adresses these first and skips the older lpt's- same applies when using an external usb-hub/splitter!)
- that there are no dma or irq conflicts
(see device manager)
- if the right driver is installed, if it suits the windows version u are using/has been written for it
- doublecheck printer against another printer
on your pc using same port
- and/or try to connect it to another pc
so u make sure on which side the error ocurs!
least: check the cable itself
Jun 13, 2009 | Zebra 105Se Thermal Printer
Eurovoxmax
Apr 09, 2009 | StarTech.com StarView SV211K 2-port KVM...
Problem with the Box digital reciever
This guide is intended for use with the Eurovox but the equipmentrequired is the same for flashing other boxes. The only differenceswill be with the relevant box firmware and its loader software.
WHAT YOU NEED:
1. Null Modem Cable ( available from here )
2. Serial to USB Adaptor ( available from here
The above adaptor assumes that you want to use a laptop to do thejob; as most recent laptops do not have a serial port, you mustpurchase the adaptor.
The Serial to USB adaptor will come with a drivers disk. So installthis before we go any further and follow on screen instructions.
Connect the adaptor to the USB port on the laptop. Connect one end ofthe the Null Modem cable to the Adaptor and the other to the serialport on the Eurovox.
Provided you have downloaded the correct version, proceed:
The file will have to be extracted. Use winzip or winrar for this procedure ( Very easy )
Ensure the Box is powered on. You can leave connected to the TV if you choose.
If you have your channels set up in Favourites we will back them upbefore flashing, although in some instances, the new update will notaffect stored channels if your firmware is not too dated.
Anyway, go to the file which you extracted and start the application. (It will be named UFL_MaxV_Kuro V........ ) Your first action will be toupload channel data. Select a name and a location for the file and saveit. It is at this point you will be alerted if the box has connectedwith the PC. If it has not, do the following:
Go to Desktop / Right click" My Computer" / Select Properties /Hardware / Device Manager / Ports & Com Ports. Now select the nextoption to appear , in my case it's prolific serial to com port. Nowselect Port settings / Advanced / Change com port to 1,2,3 or 4 / OK /Exit .
Go back to the loader screen and you should now be able to communicate with the box.
Following channel data backup, you must now download the firmware tothe box. Again, it is indicated on the screen and very easy to do. Onceinitiated, the box will display DNLD message and a progress bar willappear on the laptop screen. Allow to complete fully ! Do not disconnectuntil UPDATE SUCCESSFUL message appears on the screen. This can, insome cases, be 30seconds after 100% has been reached on the progressbar.
Finally, download your channel data and the operation is complete.
Now:
factory reset,
re scan,
go into the menu where you click on the set default key
switch on Emu
exit 3 times
wait for code to update
needs to be done after you have applied the fix,
And if that doesn't work put on Sky or Setanta orParamount+1 for a second, certain channels kickstart the process.
Hope this helps
Chris (ziraffa)
http://www.bubblecableboxes.com/forum/showthread.php?t=223
http://forums.afterdawn.com/thread_view.cfm/722659
Dec 27, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview 3
This guide is intended for use with the Eurovox but the equipment required is the same for flashing other boxes. The only differences will be with the relevant box firmware and its loader software.
WHAT YOU NEED:
The above adaptor assumes that you want to use a laptop to do the job; as most recent laptops do not have a serial port, you must purchase the adaptor.
The Serial to USB adaptor will come with a drivers disk. So install this before we go any further and follow on screen instructions.
Connect the adaptor to the USB port on the laptop. Connect one end of the the Null Modem cable to the Adaptor and the other to the serial port on the Eurovox.
If you have your channels set up in Favourites we will back them up before flashing, although in some instances, the new update will not affect stored channels if your firmware is not too dated.
Anyway, go to the file which you extracted and start the application. ( It will be named UFL_MaxV_Kuro V........ ) Your first action will be to upload channel data. Select a name and a location for the file and save it. It is at this point you will be alerted if the box has connected with the PC. If it has not, do the following:
Go to Desktop / Right click" My Computer" / Select Properties / Hardware / Device Manager / Ports & Com Ports. Now select the next option to appear , in my case it's prolific serial to com port. Now select Port settings / Advanced / Change com port to 1,2,3 or 4 / OK / Exit .
Following channel data backup, you must now download the firmware to the box. Again, it is indicated on the screen and very easy to do. Once initiated, the box will display DNLD message and a progress bar will appear on the laptop screen. Allow to complete fully ! Do not disconnect until UPDATE SUCCESSFUL message appears on the screen. This can, in some cases, be 30seconds after 100% has been reached on the progress bar.
Now:
factory reset,
re scan,
switch on Emu
exit 3 times
Hope this helps
Chris (ziraffa)
Dec 25, 2008 | StarTech.com StarView SV211K 2-port KVM...
New codes for eurovox
need provider code ie telwes / cable wirless or ntl
the lead is null cable from maplins
Dec 08, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox maxv code
i am looking new codes for eurovox max v 2008 cable box
Jun 27, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox
eurovox 2008 works fine on all free chanals but iv lost all pay chanals sky moves ect
Apr 13, 2008 | E-Machines eMachines Desktop PC
StarTech.com StarView SV211K 2-port KVM Switch Logo
235 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
