Question about Zanussi Washing Machines
Hi zanussi fjr 1254 w error code e90 what does
Hi zanussi fjr 1254 w washing machine
comes up with error code e90 what does this mean
  • Anonymous Mar 13, 2014
    zanussi washing machine FJR 1254 W error code E90
    Genius:
  • 1,847 Answers
This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts:
Thanks
Posted on Jul 01, 2009
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Error on Zanussi Electrolux Jetsystem Turbo XC FJR 1254W
    Your Washing Machine is starting to have more movement and is doing an Auto Stop, you need to get new mounts to get rid of the Excess Movement.
    Apr 08, 2013 | Washing Machines
    All lights flash and error E90 shows on my Zanussi ZWF1631 washer
    e90 is a cable problem linking main board to user board on the front
    Jan 12, 2010 | Washing Machines
    What Does Error 90 Mean on Zanussi FJS1225W Washing Machine Thank You!
    E90 - communication error between printed circuit boards. check connections.
    Oct 31, 2009 | Zanussi FJS1225W Front Load Washer
    My Zanussi washer will not start and the end light flashes 9 times. Do you know whats this means
    This indicates error code E90. Sometimes its a loose connection to the front control board. But it would usually require a replacement one Zanussi call them a user interface hope this helps you.
    Dec 17, 2008 | Zanussi FJS1225W Front Load Washer
    My zanussi will not turn on at all.
    If you give the facia a tap the display may come back on. You may then get an error code E90 being displayed. Either way you will require a new user interface pcb.
    Nov 18, 2008 | Zanussi FJS1225W Front Load Washer
    Zanussi Turbodry jetsystem 1200
    hiya
    e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
    hope this helps
    please dont forget to rate the helpfulness of this reply, thanks kj
    Jul 08, 2008 | Zanussi FJS1225W Front Load Washer
    Zanussi washing machine
    E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
    Sep 01, 2007 | Zanussi ZWF1430W Front Load Washer
    E90 Error Code
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Nov 08, 2006 | Zanussi FJS1225W Front Load Washer
    Washing Machines Logo
    871 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
