Question about Microsoft Windows Vista Ultimate Edition
I have vista ultimate computer.When I try to send message of picture using windows mail I get msg "error" The host msn cld not be found.Pls verify that you have entered the server correctly subject e-mailing account MTS server"MSN"protocal SMPT port 25Secure(ssl)no socket error11001 error number Ox800CCCOD.Any help most appreciated
  • Robert Engel
    Robert Engel May 11, 2010
    Are you using outlook express?
  • 428 Answers
Are you using Windows mail or Outlook? You need to set the sockets and outgoing server settings.
Try going to Outlook Express tools, Accounts, then click on "ISP Account".
Click "Properties", then the servers tab and check that the detail in the SMTP entry is correct for your ISP. It may be advisable to delete it and re-enter it to be sure.
Go here and do further reading.
If you use Windows Live, use one of these settings. You can check it from here, and also download the setup again. If it gives more trouble, go to Add/Remove Programs and from there you can select Repair or Change->Repair.
Check the router settings to check whether it blocked (or check the settings if you have a firewall).
For further help, please Right Click on My Computer and go to Manage and go to Event Viewer and go to the Application category and copy and send us the exact error message please.
If this answer helps you, please kindly rate the answer.
Wish You Luck.
Posted on Jul 01, 2009
  • Tharinda
    Tharinda Jul 01, 2009
    Try this tool also. But this is for Outlook. But worth trying.
    Contact you ISp also to check whether they block SMTP ports. To check whether its blocked somehow
    Get a Command Prompt (Start->Run->Type cmd and Enter)
    Type this and enter.
    Telnet sinhalaya.com 25
    (To enable telnet, go to Computer Management by RClicking on My Computer and go to Manage and go to Services.
    From there, select properties for Telnet and Enable it. Start it (Select Startup setting as Manual, after completing this, disable it coz keeping an opened Telnet port is a security vulnerability.
    If it gets connected, that means port 25 is ok.
  • Tharinda
Trying to send emails but comes up with message that "The host SMTP could not be found. Please verify that you have entered the server name correctly. POP3 Server - SMTP, Protocol:SMTP, Port 25....
Hi Your internet (mail) set up has 2 different parameters . One for Receive and second for Send. The msg you ve is ror Send , reminding you have not set it properly Open your Pc mail setup menu and find the working values there and insert these paramaters into phone setting. Thats it, Take care and please remember to vote us .thanks
Aug 01, 2011 | Lands Phones
USb SXC -1080 modem of tataindicom causes problem with vista
the usb modem you are using is compatible with windows vista but for that u need to install the driver software ie sxc 1080 vista dialer 32 bits . you can download this software from the tataindicom site which is www.tataindicom.com. windows 98 and vista have different software compatibility.
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
Error message when using my new Microsoft Windows Mail program-
You are supposed to put the fully qualified domain name of the mail server in the SMTP server field, and the POP3 server field, like mail.acmellc.com and pop3.mycompanyname.com. Contact your mail service provider if you are not sure what the server names are.
Aug 05, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Error message when I try to send an e-mail with a photo attached
it is server error. clear in your pc virus can be updated
Apr 16, 2009 | Yahoo Mail
I cannot send emails out. Can receive them,though. An error message comes up saying execution failed. Host "smtp indstream.net counld not be found. Please verify that you have entered the server...
There are several possible reasons for this. The error message looks like your using Outlook. The most common reason I see for this is when your not sending from a place that uses the same ISP as your mail host; in your case Windstream.
One thing you might try is turning off SSL in the account settings. Next, Windstream has ok tech support so you might give them a try.
Good Luck,
Steve
Sep 30, 2017 | Computers & Internet
E mailing photos
the mail id you typed may be wrong, pl. check the e. Mail address
May 26, 2008 | Dell Inspiron 1501 Notebook
0x800ccc0e message With Vista Home Premium
Symptom:
When you try to check or send any email, you get the following error messages:
The host 'pop3.example.com' could not be found. Please verify that you have entered the server name correctly. Account: 'pop3.example.com Mail Account', Server: 'pop3.example.com', Protocol: POP3, Port: 110, Secure(SSL): No, Socket Error: 11001, Error Number: 0x800CCC0D
Or
The host 'pop3.example.com' could not be found. Please verify that you have entered the server name correctly. Account: 'pop3.example.com Mail Account', Server: 'pop3.example.com', Protocol: SMTP, Port: 25, Secure(SSL): No, Socket Error: 11001, Error Number: 0x800CCC0D
Cause:
  • Problem with internet connection.
  • Incorrect anti-virus or firewall configuration.
  • Message stuck in outbox.
  • Incorrect newsgroup notification setting.
Solution:
  1. Check your Outlook Express settings.
  2. If you cannot get web pages then disconnect your internet connection and reconnect it and try again.
  3. Reboot the computer and try.
  4. Still no luck? Then check your DNS numbers, remove and reinstall your internet connection or TCP/IP.
  5. This error can also appear if you have "notify me if there are any new newsgroups" check box selected but don't have a news account set up.
    • From the menu, go to Tools -> Options -> click on General tab.
    • Uncheck the "notify me if there are any new newsgroups" check box.
Important: If you have an anti-virus program installed on your computer and if you have set the anti-virus program to scan all emails automatically, then you need to change the settings in the anti-virus program to resolve this issue. To do that, you might need to turn off the option where it says "scan your email" or something like that. Refer your anti-virus manual for instructions.
Apr 27, 2008 | Computers & Internet
E-Mailing
This is because your server that you are trying to send email on doesn't support Pop3, SMTP, etc. Make sure it supports it first before attempting to enter it into Windows Live Mail.
Feb 10, 2008 | Microsoft Windows Vista Ultimate Edition
Error message while trying to install vtp 8
first u remove u r vtp6 then u clean u r registry by the help of tuneup utillity then u install vtp8
Dec 10, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
134 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
