Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
What is cost of Gear assembly in 6.5KG, Top loading whirlpool washing machine.
  • 158 Answers
You will find everything you need at this website. Good luck Please post positive rating for me. http://www.appliancepartspros.com/bd_whirpool_washer_belt_parts.aspx
Posted on Jul 01, 2009
Washer will fill and drain, it will agitate but will not spin.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of gear oil (auto parts store) , remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Nov 14, 2010 | Kenmore Washing Machines
I am working on a Kenmore top loader washer model number 110.82873120 Problem is the machine won't spin The motor coupler is fine The pump works fine The motor (electric) works fine I think the gear case...
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-110.82873120/0582/0153200?pathTaken=
Sep 17, 2010 | Kenmore Washing Machines
Problems in spin cycle.
When ours had a similar problem, (It wouldn't start to spin unless we raised and lowered the lid a couple of times.), we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
May 07, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer 11020712990 series 70 top loader, does not spin.
When ours had the same problem (wouldn't start spinning unless the lid was raised and lowered again) we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again. (Third time was the charm.)
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil (non detergent gear oil from a local auto parts dealer), remove the clip holding the main spin gear on and check the plastic
cams.
May 02, 2010 | Kenmore 24032\24036 Top Load Washer
Washer only spins about half the time...
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24932202&pathTaken=partSearch
Your Sears parts site has a detailed diagram of the gearcase with the assembly.
cams.
Apr 26, 2010 | Kenmore 24932 Top Load Washer
Washing machine oil likeage? how to solve? what factors should be considered while repair washing machine?
your washing machine is leaking oil from the transmission. This is the gearing assembly that spins and agitates the washer while in cycle. Factors to consider, 1 cost of the assembly itself (the motor itself is possibly still in good shape) but since you have taken the machine apart to this level I would change motor out at the same time to prevent future repairs. 2 complexity of removal There are some machines that require certain types of tools to remove retaining rings. 3 Overall cost for repair, motor cost, transmission cost, tool purchase (if any) age of unit, is it worth the amount of money being put into it over the purchase of a new unit.
Good luck hope I have helped some
Dave
Jan 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Kenmore 80 series washing machine and the spin cylcle isn't working. There is a loud grinding noise during the spin cycle and the tub doesn't spin.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This also assumes that:
1. The machine will agitate and go through the rest of the cycles.
2. It will pump out the water.
3. Since it tries to spin, the Lid Switch is OK.
The problem points to the clutch and / or transmission
See the following for how to pull the clutch on Kenmore top load direct drive washers.
If the clutch springs and pads seem OK, the problem points to the main spin gear inside of the transmission. If the clutch springs and/or pads are damaged, there is a rebuild kit for them.
Following is the Whirlpool / Kenmore installation and maintenance PDF on how their top load, direct drive, neutral drain washers work.
Here is another PDF of the Whirlpool parts list for their commercial washers, consumer models are basically the same.
If you look at the operation PDF you'll see how the transmission works when going into the spin cycle. If the "Neutral Drain" cams are intact, they drive the main spin gear which drives the spin gear connected to the clutch.
If the main spin gear is broken (It's a metal plate surrounded by plastic gears) you would hear a major grinding noise and the washer wouldn't spin.
Opening the transmission is not difficult but is a messy job. It holds about 14Oz. of oil.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the main spin gear or neutral drain assembly cams are damaged, they aren't too difficult to replace.
The Whirlpool Parts PDF has part numbers for both.
The Neutral drain assembly costs about $15 which is a lot less than $170 for a new transmission.
The Main spin gear is quite a bit more but still less than a transmission.
Oct 12, 2009 | Kenmore 24032\24036 Top Load Washer
It is so loud it sounds like an airplane
Hi, there may be a leak in the gear box(transmission). check for a dry gear box. if dry, re lubricate asap. if the gear box is in good condition and, well lubricated, replace the entire drive assembly.
Jun 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer will wash clothes and it drained, but will not spin makes a loud roaring noise what is wrong?
OK, that roaring is coming from a damaged direct drive assembly. the gear box is damaged. you will need to replace asap.
Gear case housing kit with main drive gear will run you about a $190.00
Jun 03, 2009 | Whirlpool LSR5132PQ Top Load Washer
Gearbox
Assemble as follows:
Clutch assembly on top of gear box, followed by the retainer clip and then the washer. For future reference, searspartsdirect.com has helpful illustrations to assist you in component identification and assembly. Just type in your model number and follow the links on the next page. I hope this helps you.
Jun 12, 2008 | Whirlpool LSR7333 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
